SOULJA-kol Posted May 14, 2008 Share Posted May 14, 2008 is there a software to lock system tray icons?? .. example my utorrent icon my little brother exit it when he is playing..i want to lock it to not disturbing my downloads... :unsure: Link to comment Share on other sites More sharing options...
Humpty Posted May 14, 2008 Share Posted May 14, 2008 Can you right click the tray icon and hide it if it has that feature? Link to comment Share on other sites More sharing options...
SOULJA-kol Posted May 14, 2008 Author Share Posted May 14, 2008 none... i mean is there a way to compeletely hide the icon..but its service is stiill running... example is Utorrent i want to compeletely hide its icon...but it still downloading.... :unsure: Link to comment Share on other sites More sharing options...
CraigMartin Posted May 14, 2008 Share Posted May 14, 2008 none...i mean is there a way to compeletely hide the icon..but its service is stiill running... example is Utorrent i want to compeletely hide its icon...but it still downloading.... :unsure: Try this Open Utorrent->Options->Preferences->General->Uncheck, Always show tray icon............ done. Craig. Link to comment Share on other sites More sharing options...
SOULJA-kol Posted May 14, 2008 Author Share Posted May 14, 2008 its not work it is still in tray... :unsure: Link to comment Share on other sites More sharing options...
CraigMartin Posted May 14, 2008 Share Posted May 14, 2008 its not work it is still in tray... :unsure: Well its works for me I dont mean to be patronizing but you did press "Apply" You could try exiting the program, then opening it backup Craig. Link to comment Share on other sites More sharing options...
Humpty Posted May 14, 2008 Share Posted May 14, 2008 Downloaded utorrent and went through the preferences but couldn't seem to hide the tray icon without actually shutting it down. If the tray icon isn't showing it still shows in the takbar as minimized. Link to comment Share on other sites More sharing options...
CraigMartin Posted May 14, 2008 Share Posted May 14, 2008 See no tray icon for me, strange Pic removed, see below. Edit: Your right Humpty, for me as soon as you minimize it, the tray icon is back. Craig. Link to comment Share on other sites More sharing options...
Moderators DennisD Posted May 14, 2008 Moderators Share Posted May 14, 2008 What about right clicking the task bar, select properties > customize, and click in the behaviour column for that icon, and select "always hide", and apply. Also check "hide inactive icons". Out of sight, out of mind. Link to comment Share on other sites More sharing options...
SOULJA-kol Posted May 15, 2008 Author Share Posted May 15, 2008 What about right clicking the task bar, select properties > customize, and click in the behaviour column for that icon, and select "always hide", and apply. Also check "hide inactive icons". Out of sight, out of mind. i know that but i dont like that becoz just "show the hidden icons" by brother see my icon Link to comment Share on other sites More sharing options...
Tarq57 Posted May 15, 2008 Share Posted May 15, 2008 How about just don't let your brother use the computer when you are using it for something else? Link to comment Share on other sites More sharing options...
Moderators DennisD Posted May 15, 2008 Moderators Share Posted May 15, 2008 i know that but i dont like that becoz just "show the hidden icons" by brother see my icon I thought you might know that, but as no one mentioned it, I thought I would. If the little guy just won't leave well alone, why not just lock the pc until your stuffs finished. Couple of freeware apps to do this: Matrix Screen Lock: Lock PC: Both simple password activated locks. Link to comment Share on other sites More sharing options...
