Icedrake Posted April 27, 2008 Share Posted April 27, 2008 In Opera, a page never loads until I click the Reload button. For example, if I typed nationalgeographic.com, I would have to press the Reload button to make the site appear. What is the problem? Also, are there any ad-blocking widgets for Opera? Please help someone! Link to comment Share on other sites More sharing options...
Anthony A Posted April 27, 2008 Share Posted April 27, 2008 Also, are there any ad-blocking widgets for Opera? You can add filters to Opera but there are no widgets for ad blocking. Look here for filters. http://my.opera.com/Tamil/blog/ad-block In Opera, a page never loads until I click the Reload button. For example, if I typed nationalgeographic.com, I would have to press the Reload button to make the site appear. What is the problem? Some pages just don't work well in Opera. I don't come across many anymore but there are still a few. One thing you can try is to change how Opera identifies it's self. When you find a page that doesn't load properly right click a select "Edit Site Preferences" In the dialog that opens select the "Network Tab". At the bottom you we see a selection box to change how Opera identifies it's self. Try changing it to FireFox or IE. Link to comment Share on other sites More sharing options...
Icedrake Posted April 27, 2008 Author Share Posted April 27, 2008 Thanks for the help Anthony! I'll try your instructions! EDIT: Could you kinda explain how I add each of these stuff to Opera? I'm kind of confused with where to put everything... Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted April 27, 2008 Moderators Share Posted April 27, 2008 Did you mean it happens with all pages you try to load? Are you getting lots of ad popups? Antivirus scans etc up to date? Perhaps you could try clearing your browser cache as well. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Icedrake Posted April 27, 2008 Author Share Posted April 27, 2008 It's not happening anymore now, Hazel and Anthony. A quick reinstall fixed everything! Also, I got your ad-blocking suggestion to work. You have to edit a specific file. Thanks for all the help everyone! EDIT: One more question: Is there anyway to stop History from getting recorded in Opera? Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted April 27, 2008 Moderators Share Posted April 27, 2008 You could always go opera-tools-preferences-advanced-history-tick empty on exit-ok Are you hiding something Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Icedrake Posted April 27, 2008 Author Share Posted April 27, 2008 Umm?? Anyway, I don't exactly see an option to clear History on exit in Opera 9.5 Beta 2 Link to comment Share on other sites More sharing options...
Anthony A Posted April 27, 2008 Share Posted April 27, 2008 You want to go here Set your options there. If by history you also mean cookies Opera can be set to clean cookies on exit. You can easily white list cookies you want to keep as well Link to comment Share on other sites More sharing options...
