Newhotness Posted June 23, 2005 Share Posted June 23, 2005 Hi all, so a friend of mine at work has just realized that a VERY important folder has just been deleted. This folder was on a network drive, and she doesn't know who deleted the folder, she just needs it back. Any suggestions? Link to comment Share on other sites More sharing options...
DjLizard Posted June 23, 2005 Share Posted June 23, 2005 Stop using the drive immediately. The more you [or the OS] writes to it, the more you lose. Move the drive to another machine, as a slave drive. Test a product such as GetDataBack NTFS (if the drive is NTFS) : http://www.runtime.org/gdbnt.zip (Install the program to the host operating system, not the drive which needs recovery!) It'll be a demo, but it will give you an idea of whether you're going to get the directory back or not. I use this program a lot (as well as Ontrack's EasyRecovery Pro) Click here if CCleaner Issues are re-appearing DjLizard.net DjLizard.net wiki Dial-a-fix Dial-a-fix tips DjLizard.net software support forum Do you live in Bradenton, Sarasota, Tampa, or St. Petersburg, Florida? Visit Digital Doctors where I work Link to comment Share on other sites More sharing options...
