vmo1701 0 Posted March 18, 2008 Share Posted March 18, 2008 I'll give it a shot and check with you later. Link to post Share on other sites
vmo1701 0 Posted March 18, 2008 Share Posted March 18, 2008 I did what you said and installed the slim version. However, the same problem occurs. Any more suggestions would be appreciated. Link to post Share on other sites
davey 0 Posted March 19, 2008 Share Posted March 19, 2008 I did what you said and installed the slim version. However, the same problem occurs. Any more suggestions would be appreciated. Hello vmo1707, I guess you read how the other member found a "worm" was causing his problem. Are you having any problems with any of your security programs? Have you run any security scans? Can you run some root-kit scans also? Try these online scanners. Eset online scan http://www.eset.com/onlinescan/ http://housecall.trendmicro.com/ Trend Micro Housecall free online Good Luck, davey Link to post Share on other sites
