Eli Posted February 2, 2008 Share Posted February 2, 2008 Can anybody explain which elements of applications CCleaner cleans for the following: 1.Antivirus/antispyware 2.office 3.pdf reader 4.java sun 5.windows ms paint,ms word pad,regedit 6.multimedia. Request to be more specific than the "Temporary files answer...." and please advice the deletition consequences of the a/m. Thanks in advance. Eli OS : MS windows XP pro sp3 Processor : AMD Athlon 64x2 Dual core 3800, 2009Mhz.Mother board : Gygabyte M61 PM-S2 Ram : 3GBDisk space : 649.05 GB Default browser: FirefoxProtection : Sandboxie, MBam free version Link to comment Share on other sites More sharing options...
CeeCee Posted February 2, 2008 Share Posted February 2, 2008 Mostly MRU (most recently used files) list. Also can clean some .log files for Antivirus/antispyware. Path Copy TeraCopy Unlocker Link to comment Share on other sites More sharing options...
Eli Posted February 3, 2008 Author Share Posted February 3, 2008 Mostly MRU (most recently used files) list. Also can clean some .log files for Antivirus/antispyware. Can you advice please the deletition consequences of the a/m ?thanks . Eli OS : MS windows XP pro sp3 Processor : AMD Athlon 64x2 Dual core 3800, 2009Mhz.Mother board : Gygabyte M61 PM-S2 Ram : 3GBDisk space : 649.05 GB Default browser: FirefoxProtection : Sandboxie, MBam free version Link to comment Share on other sites More sharing options...
CeeCee Posted February 3, 2008 Share Posted February 3, 2008 Can you advice please the deletition consequences of the a/m ?thanks . Eli What's a/m? Path Copy TeraCopy Unlocker Link to comment Share on other sites More sharing options...
davey Posted February 3, 2008 Share Posted February 3, 2008 (edited) Hi Eli, I think it may help if you review the contents of the winapp.ini file at C:\Program Files\CCleaner. This will help answer some of your questions. Also this link may help if there are other areas you might want to clean. http://forum.piriform.com/index.php?showtopic=1110 davey P.S. You might want to run the Cleaner function and just use the Analyze button. You should also check off the options and uncheck the options to get an idea what each is going to clean .I would also check the boxes at Options > Advanced to show the detailed logs of IE and Firefox/Mozilla.Also review the Cookies list at Options > Cookies. Edited February 3, 2008 by davey Link to comment Share on other sites More sharing options...
Eli Posted February 3, 2008 Author Share Posted February 3, 2008 What's a/m? a/m= above mentioned Regards ELI OS : MS windows XP pro sp3 Processor : AMD Athlon 64x2 Dual core 3800, 2009Mhz.Mother board : Gygabyte M61 PM-S2 Ram : 3GBDisk space : 649.05 GB Default browser: FirefoxProtection : Sandboxie, MBam free version Link to comment Share on other sites More sharing options...
CeeCee Posted February 4, 2008 Share Posted February 4, 2008 Can you advice please the deletition consequences of the a/m ?thanks . Eli MRU's will be deleted (from the registry). And maybe some .log (ETC) files. Result is less unneeded files in your hard drive and clean MRU list(s). Edit: For 'Sun Java' it deletes cache files (cached Java files), from this location: C:\Documents and Settings\<user>\Application Data\Sun\Java\Deployment\cache. Path Copy TeraCopy Unlocker Link to comment Share on other sites More sharing options...
hotdoge3 Posted February 5, 2008 Share Posted February 5, 2008 Temp Cookies dat History MRUs URLs see the list run & have a look ok clean if you see Windows up Date dont clean for a few days so it can fit fist [ 12 feb 08 dont clean ] clean on the monday or sunday. Link to comment Share on other sites More sharing options...
