CCleaner Community Forums
Need help with Zone Alarm
Bavaria
 Share
He wrote that program himself. It still impresses the hell out of me too.
Look here for more info:
http://forum.CCleaner.com/index.php?showtopic=1087&hl=
Did we fix your problem?
For the moment ,i need the internet, so i didnt disconnect! :) If is not working ,i will ask again for help! :)
Tarun, thx again for help!
Can you tell me how it works, hijack this?Just basics!I am not good with computers,but i want to learn! :)
Link to comment
I installed again ZA.Same problem :(
If i shutdown ZA, still not working.I uninstalled ZA,restart the computer,internet ok,disconnected for 10 min,connect back on internet ok. :unsure:
What could be the reason, that the internet connection is ok ,but cannot open any page on internet?
Any ideas, how can i fix the problem?
Thx!
Link to comment
  • Moderators
ZoneAlarm Pro any version has always killed my dial-up connection with my current ISP, I don't know if it's an advanced Pro only feature that does it. The free version has never caused connection problems.
When I had connection problems a few years ago and called my ISP one of the first things they asked was "Are you using ZoneAlarm Pro."
Link to comment
What version are you trying to use at the moment, free or pro?
Could you open up zonealarm, then click program control on the left hand side, click the programs tab top right, you will now see what is being allowed or disallowed to the internet.
Could you print screen this and post it in here, so we can see it? Or just tell us if that is easier.
Link to comment
Free version.I
All the programs are on green.I did this just to check.Not working.
Link to comment
Check the picture pls!
Sorry, was that pic there before?
It is not program access that is a problem then. You are actually allowing to much access.
Change all the ticks to crosses under the server column, it wont help the problem but needs to be done.
Link to comment
What browser are you using?
Is it internet explorer? If it is, have you kept your computer up to date using windows update?
I am just thinking it could be a conflict between zonealarm and an outdated version of IE.
Have you tried using a different browser such as Firefox?
Link to comment
Is updated.Internet Explorer.Never used Firefox.
Link to comment
What about giving Firefox a try anyway, it is a much more secure browser anyway, due to the fact that most malware is designed to exploit security flaws in IE.
You never know it might just cure your problem.
Link to comment
I just find a fix! :)
If i shutdown the ZA ,before i disconnect the internet, is ok.I can connect again on the internet and after this ,restart ZA.
Link to comment
Register a new account
Sign in
 Share
