CCleaner Community Forums
help me out here for an old console
hi, i have a Sega Dreamcast with a 56k Modem built in of course. there is a guide Here to hook the Dreamcast towards the PC to gain online accees through the USB 56K modem or PCI modem within the PC. it's a windows 98 guide but i'm sure it's easy to do with Xp. please help if you can. Thx!
P.S - i kow they stated Win98 only works but hey i would like to try it with Xp
Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8
Link to post
  • Moderators
I've never heard of doing it that way before. Although I know first hand that using the DC's built in dial-up modem is rather easy to setup because I used it myself years ago but just for the sake of trying it. Those instructions look rather involved.
Link to post
yeah, but i know it's possible. can't be all that different. i may be ending up having to buy the Broadband Adapter as i'm having no luck yet. i don't have the PlanetWeb Browser so i'll have to buy that as well. i've been using Sonic Adventure's Web Browser and idk... if that will work.
Link to post
Register a new account
Sign in
