Capman Posted June 6, 2005 Share Posted June 6, 2005 Just out of curiosity, how many Running Processes and Process Modules do you have when performing an Ad-Aware scan? I have 35 Running Processes and 1357 Process Modules. Would this be considered as normal/average? I do appeciate everyones will be different, and there is probably no such thing as normal/average. Would be interesting to find out about others though. Link to comment Share on other sites More sharing options...
Tarun Posted June 7, 2005 Share Posted June 7, 2005 Perfectly normal. Mine are generally 25-35. Link to comment Share on other sites More sharing options...
DjLizard Posted June 7, 2005 Share Posted June 7, 2005 38/1754 Click here if CCleaner Issues are re-appearing DjLizard.net DjLizard.net wiki Dial-a-fix Dial-a-fix tips DjLizard.net software support forum Do you live in Bradenton, Sarasota, Tampa, or St. Petersburg, Florida? Visit Digital Doctors where I work Link to comment Share on other sites More sharing options...
Tarun Posted June 7, 2005 Share Posted June 7, 2005 I just set a new record for myself. 20/834 Link to comment Share on other sites More sharing options...
agumon Posted June 7, 2005 Share Posted June 7, 2005 22 running processes 1039 process modules what is process module...? --==aGumon==-- Link to comment Share on other sites More sharing options...
DjLizard Posted June 7, 2005 Share Posted June 7, 2005 like a DLL Click here if CCleaner Issues are re-appearing DjLizard.net DjLizard.net wiki Dial-a-fix Dial-a-fix tips DjLizard.net software support forum Do you live in Bradenton, Sarasota, Tampa, or St. Petersburg, Florida? Visit Digital Doctors where I work Link to comment Share on other sites More sharing options...
Moderators rridgely Posted June 7, 2005 Moderators Share Posted June 7, 2005 31/1192 Link to comment Share on other sites More sharing options...
agumon Posted June 8, 2005 Share Posted June 8, 2005 like a DLL so is it something like a DLL that is currently running? --==aGumon==-- Link to comment Share on other sites More sharing options...
Tarun Posted June 8, 2005 Share Posted June 8, 2005 so is it something like a DLL that is currently running? <{POST_SNAPBACK}> Dynamically Linked Library - (DLL) - A library which is linked to application programs when they are loaded or run rather than as the final phase of compilation. This means that the same block of library code can be shared between several tasks rather than each task containing copies of the routines it uses. The executable is compiled with a library of "stubs" which allow link errors to be detected at compile-time. Then, at run time, either the system loader or the task's entry code must arrange for library calls to be patched with the addresses of the real shared library routines, possibly via a jump table. The alternative is to make library calls part of the operating system kernel and enter them via some kind of trap instruction. This is generally less efficient than an ordinary subroutine call. It is important to ensure that the version of a dynamically linked library is compatible with what the executable expects. Examples of operating systems using dynamic linking are SunOS (.so - shared object files), Microsoft Windows (.dll) and RISC OS on the Acorn Archimedes (relocatable modules). Learn More... Link to comment Share on other sites More sharing options...
agumon Posted June 9, 2005 Share Posted June 9, 2005 a new scan offline... and this is what i got: --==aGumon==-- Link to comment Share on other sites More sharing options...
