SkeeterBeeter Posted June 9, 2005 Author Share Posted June 9, 2005 That does sound rather weird. O.o <{POST_SNAPBACK}> FYI==> After I created a new account I imported the settings and the mail. This prompted the server to add another account which was my Bosses with His user name & email addy but with my server settings????? This is why I couldn't type in the right password because the server was trying to log Him in instead of myself. I just removed His account and everything was fine.... Link to comment Share on other sites More sharing options...
SkeeterBeeter Posted June 9, 2005 Author Share Posted June 9, 2005 Windows NT 4 is very old and you probably should consider upgrading the computer to Windows 2000, Windows XP or Linux. If not, then be sure to use the latest service pack! <{POST_SNAPBACK}> I don't run out and buy a new OS everytime I have a small glitz in my current OS. I try to isolate the problem , then analyse a solution , then implement the solution and if I cannot solve a particular problem I reply with knowledgable people who have the expertise to eliminate the glitz.... You see the key is finding the right people to fix your problem.... But , thanks for the suggestion. Link to comment Share on other sites More sharing options...
DjLizard Posted June 9, 2005 Share Posted June 9, 2005 Leave it to Eldmannen to suggest complete replacement ?_? Click here if CCleaner Issues are re-appearing DjLizard.net DjLizard.net wiki Dial-a-fix Dial-a-fix tips DjLizard.net software support forum Do you live in Bradenton, Sarasota, Tampa, or St. Petersburg, Florida? Visit Digital Doctors where I work Link to comment Share on other sites More sharing options...
