"CCleaner has encountered a problem..."
I've been running CCleaner since version 1.31. I never had a single problem until version 1.40. Now, I find the same problem when running 1.41. Here's my computer setup...
System Model
Windows XP Professional Service Pack 2 (build 2600)
Dell Computer Corporation Dimension XPS
Enclosure Type: Mini-Tower
Processor a Main Circuit Board b
2.80 gigahertz Intel Pentium 4
8 kilobyte primary memory cache
512 kilobyte secondary memory cache
Board: Dell Computer Corp. 0F2905
Bus Clock: 800 megahertz
BIOS: Dell Computer Corporation A02 07/21/2003
Drives Memory Modules c,d
283.93 Gigabytes Usable Hard Drive Capacity
143.94 Gigabytes Hard Drive Free Space
_NEC DVD+RW ND-1100A [CD-ROM drive]
LITEON DVD-ROM LTD163 [CD-ROM drive]
3.5" format removeable media [Floppy drive]
Maxtor OneTouch II USB Device [Hard drive] (203.92 GB) -- drive 1
WDC WD800JD-55JRC0 [Hard drive] (80.02 GB) -- drive 0
2048 Megabytes Installed Memory
I'm cleaning and shredding drives C: and F: (3 passes). F: is a Maxtor Hard Drive connected via a USB Port. CCleaner is installed on drive C:. In the middle of the operation I get the following error from the operating system....
CCleaner has encountered a problem and needs to close.... Please tell MicroSoft about this problem. The "error" data that's being sent to microsoft is as follows....
C:\DOCUME~1\owner\LOCALS~1\TEMP\WERfa8f.dir00\CCleaner.exe.mdmp
C:\DOCUME~1\owner\LOCALS~1\TEMP\WERfa8f.dir00\appcompat.txt
Like I said, all versions earlier than 1.40 worked perfectly. Any suggestions?
Yak
Link to comment
Register a new account
Sign in
Important Information
