tommyk Posted July 31, 2007 Share Posted July 31, 2007 I finally was able to switch to DSL and love the speed. However, CC doesn't seem to be cleaning my internet use. I can do it manually, though. Any ideas? Link to comment Share on other sites More sharing options...
Kaiba Posted August 1, 2007 Share Posted August 1, 2007 Make sure you check every CC setings options and so on. Windows and Applications Link to comment Share on other sites More sharing options...
tommyk Posted August 2, 2007 Author Share Posted August 2, 2007 Make sure you check every CC setings options and so on. Windows and Applications I have everything checked for Settings . . . On Advanced I have only Show Prompt to Backup Registry checked. Never had any problems with CC cleaning tracks before with dial up but since switching to DSL it's not cleaning. I have to do it manually. Link to comment Share on other sites More sharing options...
fireryone Posted August 3, 2007 Share Posted August 3, 2007 I finally was able to switch to DSL and love the speed. However, CC doesn't seem to be cleaning my internet use. I can do it manually, though. Any ideas? Do you mean its not cleaning the temporary files and cookies and history? You could try cunning a clean with only one item selected at a time, and try different secure delete methods. fireryone Link to comment Share on other sites More sharing options...
