CCleaner Community Forums
kellie
Load CCleaner on external hard drive
How do you load CCleaner onto an external hard drive? I am using it with great success on the main drive but also want to use it on the external where I keep a copy of everything thats on my main drive. Help appreciated.
Share this post
Link to post
Is there actually anything on the external hard drive that CCleaner could clean?
Share this post
Link to post
Fragmented itune files.
Share this post
Link to post
CCleaner does not defragment files.
Share this post
Link to post
I think they just want to be able to run it from a usb drive without having to install it.
It would clean drive C: but from the thumbdrive, & without install.
Share this post
Link to post
CCleaner Portable
Is this what he is looking for? You can run it from a USB drive, but only if the main PC doesn't have it installed already.
AJ
Share this post
Link to post
Hi all, or you could use this batch file that I made a while ago ;) - the cool part is that it will 'auto-detect' if CCleaner is already installed on the 'Target' PC and if it is then simply run it. However, if it does not find a previous installation it then installs it in the background, runs then uninstalls itself without any user interaction :D
@ECHO OFFECHO  %date% - %time%: CCleaner InitializingIF EXIST "%systemdrive%\program files\CCleaner" GOTO RUNLOCALCCgoto RUNTUNEUPCC:RUNTUNEUPCCCALL ".\Tools\Applications\CCSetup.exe" /SCALL "%systemdrive%\program files\CCleaner\CCleaner.exe"CALL "%systemdrive%\Program Files\CCleaner\uninst.exe" /SECHO  %date% - %time%: FinishedECHO.GOTO END:RUNLOCALCCCALL "%systemdrive%\program files\CCleaner\CCleaner.exe"ECHO  %date% - %time%: FinishedECHO.:END
Simply update the paths as required to where your .exe is located on your USB pen drive etc...
Hope this helps
Share this post
Link to post
Register a new account
Sign in
