kirkie Posted May 19, 2007 Share Posted May 19, 2007 Hi guys, before I go any further I have asked this question on other forums, but so far I haven't found the answer. My Disk drive shows what I can only describe to be a no entry sign over the icon. This is not allowing me to use the drive. If I plug an mp3 play into the computer it also shows the no entry sign. I am currently using Vista and recently used CCleaner and did an Issue scan. I deleted all the issues and created a back up. Everything seemed to be running OK, but didn't check the drives. However since then I have permanently deleted my backup. I'm not sure if this is the cause, but would love as much help as possible to resolve this issue... Thanks in advance... Link to comment Share on other sites More sharing options...
1200 Posted May 19, 2007 Share Posted May 19, 2007 i don't think it has anything to do with the registry issues. Could it be the UAC thing? umm, i am kinda confuse with your problem Nlite Tutorial, Wireless Security Tutorial Link to comment Share on other sites More sharing options...
kirkie Posted May 19, 2007 Author Share Posted May 19, 2007 I have found the answer on the following forum, but looks a temporary solution... http://forums.microsoft.com/TechNet/...2422&SiteID=17 It was all down to Acer Elock... Link to comment Share on other sites More sharing options...
1200 Posted May 19, 2007 Share Posted May 19, 2007 The link does not works Nlite Tutorial, Wireless Security Tutorial Link to comment Share on other sites More sharing options...
kirkie Posted May 19, 2007 Author Share Posted May 19, 2007 Try this one https://forums.microsoft.com/TechNet/ShowPo...2&SiteID=17 Link to comment Share on other sites More sharing options...
1200 Posted May 19, 2007 Share Posted May 19, 2007 so does it works for you? Nlite Tutorial, Wireless Security Tutorial Link to comment Share on other sites More sharing options...
kirkie Posted May 19, 2007 Author Share Posted May 19, 2007 It has for now and we will see for how long.... Link to comment Share on other sites More sharing options...
