As a lot of people are using Yandex Browser, is there a way to add full Yandex Browser Cleaning Option in CCleaner ?
When i am running CCleaner, it only cleans parts of Yandex Data.
Thanks!
Thanks!
You can set the profile location for Yandex using the information described here: https://support.piriform.com/hc/en-us/articles/360048432991
This should then allow CCleaner to clean the browser using the Cleaning Rules for Google Chrome (and thus the only the selected Rules will have an effect, so it won't clean the Cache if the Cache Cleaning Rule is unchecked.
Please also ensure that you use the Custom Clean mode when using this setting.
