x64 seems to have problems with the registration of the open and run shortcuts. I see member Chun had listed this error in an earlier posting but there was no reply. Will this be corrected or just left as is? The latest version "1.36.430" is still non functional in this area. Would seem to be a simple fix but what do I know.
The rest of the program seems to function properly. Thanks in advance for a reply.
I have the same problem too :/
Hope they fix it soon.
Damn im waiting so *** long for damn 64 bit version of CCleaner.
When can i get CCleaner x64?
Does it take so much time to compile a 64 bit version of this SMALL programm? OMFG
Microsoft Windows XP Professional x64 Edition (2005)
There will be a new version of CCleaner out this week, see here for info
http://forum.CCleaner.com/index.php?showtopic=8773
Perhaps the improved support for x64 may help with your problem.
Windows drops the regkeys into the wrong location to provide 32-bit compatibility. (HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\Shell)
Use this file to correct the registration issue.
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\Shell]
[HKEY_CLASSES_ROOT\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\Shell\Open CCleaner...]
[HKEY_CLASSES_ROOT\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\Shell\Open CCleaner...\command]
@="C:\\Program Files (x86)\\CCleaner\\CCleaner.exe"
[HKEY_CLASSES_ROOT\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\Shell\Run CCleaner]
[HKEY_CLASSES_ROOT\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\Shell\Run CCleaner\command]
@="C:\\Program Files (x86)\\CCleaner\\CCleaner.exe /AUTO"
