Today I updated speccy and it said my MB was 114c! there's just NO way it can be that hot. If I remember correctly the older version of speccy didn't even come close to displaying it as that hot. But sure enough..
https://gyazo.com/2015e2c65401f8fab8d1c61ab5d52a86
So I tried another program…
https://gyazo.com/f458920989b0a31c1b2d8059845c6d95
Same thing! if it matters I did dust/clean out my PC a few days ago and just gave it another quick clean just to make sure. I even booted into the BIOS and my BIOS said my MB was like 26c! there’s just no way it can be this hot…am I imagining things? I got this MB maybe like…in the summer? Juneish? so it can’t possibly be broke can it? does anyone have any other suggestions for checking my temp?
https://gyazo.com/63494b8f4788a67e03dfdf235165a45d my CPU/ram usage isn’t that bad either. So what on earth could be causing such a bad temp spike?
https://gyazo.com/917d31f82cd8e83f094d3b17469eb048 same result ![]()
So is this just some sort of API issue? I downloaded an old version of speccy and it seems to be displaying correctly. I got a friend to try and update his speccy but his is fine…
Is anyone else getting incorrect temps from temp gauges?
