As you can see from the image below, speccy is showing wrong temperature for my SSD
(128°C)
I guess it simply does not convert it from Fahrenheit to celsius (128 degrees fahrenheit=53 degrees celsius)
The i7 core temperature is OK, i've a water cooling system, but there's a problem with the GTX 670, not showing current temperature.
