It's a bit strange don't u think? I open CCleaner, and it tells me that I have a AMD Sempron 2800+
Well, I don't know exactly what I have, but another program, "Belarc Advisor" tells me that I have a AMD Athlon 64 2800+ !
That's a small difference isn't it? ![:D]()
Here a screenshot:
CCleaner:
Belarc Advisor:
Wich of the two is right? ![:huh:]()
Check under your My Computer.
Right-Click My computer and go to Properties.
If all else fails you can go and download CPU-Z
http://www.cpuid.com/cpuz.php
Thanks very much zaphirer for your help. The results are less fine... I've a Sempron...
It seems CCleaner is beter then a specialy designd program... ![:D]()
CPUid is very intresting, by the way. ![:rolleyes:]()
