Hi,
My i3-4170 displayed as i3-4360. Pls correct that.
Hi,
Speccy only displays what it gets from WMI Services.
If Speccy shows 4170, it's getting that data from the firmware.
To confirm, start a Command Prompt, type wmic and press Enter, then type cpu get name and hit Enter.
Also have an issue with CPU identification. My CPU is a Pentium G4500 (3.5 GHz Skylake) and Speccy indicates i5-6600K on the summary page - which I copied and pasted below:
Quote "
Great program otherwise, reassures my system is running as cool as I designed it to run.
