trium
1
Betriebssystem
MS Windows XP Professional 32-bit
CPU
AMD Athlon XP
AMD Athlon XP
Thoroughbred 0.13um Technologie -- is only one core at athlon xp. :-)
RAM
512MB DDR (2.5-3-3-5)
Motherboard
K7VT2 (Socket-A) 45? C
Grafik
S/M 750p (1024x768@60Hz)
128 MBNVIDIA GeForce4 Ti 4200 (Albatron)
Festplatten
78GB Western Digital WDC WD800JB-00JJC0 (ATA) 30? C
Optische Laufwerke
HL-DT-ST DVD-ROM GDR-H30N
HL-DT-ST DVDRAM GSA-4163B
Generic DVD-ROM SCSI CdRom Device
Audio
Unimodem Halbduplex Audioger?t ?
another question: why is at point "audio" not my soundblaster at first soundcard? Instead, my modem at first?
Audio
Soundkarten
Creative AudioPCI (ES1371,ES1373) (WDM)
Abspielger?te
Creative Sound Blaster-PCI
Modem Nr. 0 Line-In
Aufnahmeger?te
Modem Nr. 0 Line-Out
Convention is to list sound cards first, followed by other devices with audio capabilities such as a modem.
Can you please PM me your .speccy files?
trium
5
I once an image of Speccy version 1.10 made...for my first post ^
what do you mean with "speccy files"? the install-files?
Nergal
6
Within Speccy Go
File
Save SnapShot
This will create a file of the type .Speccy
trium
7
i send you the speccy file later...
the cpu indicator is correct in the version 1.11.
but the audio card detection to be wrong...
trium
8
perhaps there's another error
in graphics is a wrong shader version i mean...
the nvidia geforce 4 ti 4200 supports
vertex shader 1.1 and
pixel shader 1.3
not shader model 1.4! with shader model 1.4 would run gothic 3! but it doesnt run.
with open gl 1.4 im not sure...
