Greetings All,
I have a Amd 4200+ and it usually shows a core speed of 2204.8 and a multiplier by 11 and sometimes fluctuates down. Now it stays as the one specified. Am I reading something wrong?
CPU
AMD Athlon 64 X2 4200+
Cores 2
Threads 2
Name AMD Athlon 64 X2 4200+
Code Name Manchester
Package Socket 939
Technology 90nm
Specification AMD Athlon 64 X2 Dual Core Processor 4200+
Family F
Extended Family F
Model B
Extended Model 2B
Stepping 1
Revision BH-E4
Instructions MMX (+), 3DNow! (+), SSE, SSE2, SSE3, AMD 64
Virtualization Unsupported
Hyperthreading Not supported
Fan Speed 1629 RPM
Bus Speed 200.4 MHz
Rated Bus Speed 1002.2 MHz
Stock Core Speed 2200 MHz
Stock Bus Speed 200 MHz
Average Temperature 42 ?C
Caches
L1 Data Cache Size 2 x 64 KBytes
L1 Instructions Cache Size 2 x 64 KBytes
L2 Unified Cache Size 2 x 512 KBytes
Core 0
Core Speed 1803.8 MHz
Multiplier x 5.0
Bus Speed 200.4 MHz
Temperature 40 ?C
Thread 1
APIC ID 0
Core 1
Multiplier x 5.0
Bus Speed 200.4 MHz
Temperature 43 ?C
Thread 1
APIC ID 1
Thank you for yout help.
Pastor William
Modern CPUs are capable of speed throttling in order to greatly reduce power consumption when the CPU is mostly idle. Power management in Windows XP and 7, when set to any mode other than Always On, enables power management features for the CPU. Laptop, notebook and netbook manufacturers may also implement CPU power management options either in BIOS or via proprietary utilities installed on the computer.
Thank you Gonetoplaid,
Yes I agree and acknowledge that is true and definately happens here, however, the speed from the time you start speccy to the end after hours of running stays stationary and the multiplier will change frequently. Under any stress from idle to running a stress test which in previous versions changed the speed with usage as well as the multiplier.
Thasnks
Pastorwilliam
