wireless connection
Hello!!, could anyone please help me figure out my wireless connection problem; it connected with 3 bars and only said" Access: local only, it supports to say ' access: local and internet' in order to connect to the internet. Strange thing though, sometime it ables the search the net if i put work offline, but only one time though, if i click on anything it pop up a box said that i need to connect to the internet and if i put offline again it won't works. click on connect then it won't works because it need to say local and internet- little icon that has two small computer at the bottom right corner .any help would be appreciated
Hi 1200, I've just been looking into Wireless myself over the last few days, so I haven't gotten as far as connecting stuff up yet, so can't be of much help to you.
But maybe if you post again in "Hardware", someone will try and help you out. :)
Yeah, it took me forever to get my wireless network, printing,p2p, etc. all set up properly. just hope i dont have to do it again for a long time!
