Can someone give the link to the winsys2.ini, sorta like winapp2.ini with a big list of apps
Thanks
Thanks
AFAIK there is not one made though it is, i believe, Possible.
There isn't like Nergal has stated. The only one available is included with CCleaner itself, also anything using Special Keys for detection can't be made by any of us end-users.
Is it still true that no community-maintained winsys2.ini file exists, analogous to winapp2.ini?
Yup, just Winapp2.ini (as far as I know).
Though it has pretty many entries and it's updated frequently:
Latest Update:December 12'th, 2012
# Entries in this version: 1,113
I was maintaining two separate versions of winapp2.ini for a while
One with all entries, one with some segregated into a winsys2.ini
it became troublesome to keep doing that, so I stopped.
