Anyone know how I would go about adding an entry to the WINAPP2.INI file to clear the Windows print spooler? For those times when the print cue gets fubarred, this might be handy.
Hi WickedGirl.
Maybe this will help. A simple batch file which does the job:
I've been using that myself ever since you first posted it! It comes in handy with HP printers taking forever to do maintenance when they're supposed to be printing instead.
That and a winapp2.ini entry wouldn't work for it, the Print Spooler service has to be stopped first which is what DennisD's batch file does.
You should pin that topic.
