Winapp2.ini additions
New entry
[Western Digital Dashboard *]
LangSecRef=3024
Detect=HKLM\SOFTWARE\Western Digital\SSD Dashboard
FileKey1=%LocalAppData%\Western Digital\Dashboard\cache\QtWebEngine\Default\Cache|*|RECURSE
FileKey2=%LocalAppData%\Western Digital\Dashboard\QtWebEngine\Default|*.old
FileKey3=%LocalAppData%\Western Digital\Dashboard\QtWebEngine\Default\GPUCache|*|RECURSE
FileKey4=%ProgramFiles%\Western Digital\SSD Dashboard|dashboard.log
I don't know if Archived entries.ini or Winapp3.ini are being maintained anymore, but here is something of note.
I found it odd that these Winapp3.ini entries will no longer show up in CCleaner 6.16 when they are pasted into WinApp2.ini even though they are properly formatted:
[Chrome Indexed Database Extended *], [Chrome Installer *], and [Chrome Local Storage Extended *]
What I have found is that entries starting with "Chrome", or contain "Section=Dangerous Google Chrome" will not show up in CCleaner's list.
Changing these entries to:
[Chromium Indexed Database Extended *]
Section=Dangerous Chromium
(... rest of entry etc.)
[Chromium Installer *]
[Chromium Local Storage Extended *]
[Chromium Software Reporter *]
solves it and the entries then work correctly. It is very strange, but seems to be a quirk in CCleaner. WinApp3.ini and Archived Entries.ini are both affected.
4 hours ago, PICPro said:
	<pre class="ipsCode prettyprint lang-html prettyprinted"><span class="pln">[Chromium Indexed Database Extended *]
(… rest of entry etc.)
very odd, is this a recent development or just something you recently noticed
I'm don't know what version of CCleaner that this changed. I'm pretty sure that those entries used to work as is. I recently installed Thorium browser on my WIndows 7 x64 computer to have a more up to date Chromium based browser. I added Thorium lines to the [Chromium ... *] entries in Winapp2.ini and that all went well, but when I tried to use the additional entries from Winapp3.ini, I noticed that the [Chrome ... *] entries didn't show in CCleaner's list event though the detects were satisfied. I found that both the entry name and the section name affected this and I am using CCleaner 6.16 at the moment. It is very weird indeed.
Anyone else want to try it?
What happened to all of the Microsoft store apps entries?
It has been more than two months and no update.
I was wondering this too. I'm showing no Windows Store entries from Winapp2.ini on Windows 10 or 11.
As far as I know, @Winapp2.ini has abandoned the "Microsoft Store" category and sorted the applications into their respective categories. (I guess it has already been questioned why the "Microsoft Store Apps" were given their own category, although they could have simply been sorted into the existing categories.)
The entries are still there, but @Winapp2.ini has merged some of them. The easiest way to find them is to search for "DetectFile=%LocalAppData%\Packages\".
Thanks for the explanation APMichael? Fully recognizing that WinApp2.ini has been and still is fully voluntary, I continue to wish that we would get more frequent updates again. ?
I found a new cache path that needs cleaned for Microsoft Edge Chromium:
%LocalAppData%\Microsoft\Edge*\User Data\GraphiteDawnCache
	<pre class="ipsCode prettyprint lang-html prettyprinted"><span class="pln">%LocalAppData%\Microsoft\Edge*\User Data\GraphiteDawnCache</span></pre>
When I run CCleaner and then immediately check the User Data folder, all the caches have been cleared. This applies to Windows 10/11 x64.? My only browser is MSEdge Chromium (latest version).
On 20/11/2023 at 00:08, siliconman01 said:
		When I run CCleaner and then immediately check the User Data folder, all the caches have been cleared.  This applies to Windows 10/11 x64.<span class="ipsEmoji">?</span>  My only browser is MSEdge Chromium (latest version).
That folder had cached files in it on my system. When looking at winapp2.ini online (direct download version), it didn't clean that folder, there was no reference of it. I also have Microsoft Edge Chromium (latest version).
Edit:
That "GraphiteDawnCache" folder was a relatively new creation, the creation stamp date states "Tuesday, ‎August ‎22, ‎2023", and I know it was not in there for very long because once in a while I go about snooping in there to see what they've added.
The following FileKey matches the folder and removes it:
Version: 230901
[Microsoft Edge Caches *]
FileKey17=%LocalAppData%\Microsoft\Edge*\User Data\*Cache*|*|REMOVESELF
That explains why I couldn't find it, being it's a wildcard entry, and my winapp2.ini may have been outdated, don't know.
BUT (a big BUT), I don't like deleting "REMOVESELF" cache folders, instead I clean them out, due to past issues of deleting them outright.
How I clean that folder:
%LocalAppData%\Microsoft\Edge*\User Data\GraphiteDawnCache|*.*|RECURSE
Two more. Don't know if it's from Microsoft Edge Chromium, or Windows Updates, or something else.
Both created on November 8, 2023 within 7 minutes of each other.
Contains telemetry data:
C:\ProgramData\profile_count_updates.json
Was empty:
C:\ProgramData\UpdateLock-updates
If anyone cleans Windows Update logs in their own personal winapp2.ini file there's another area to clean them from now also:
%CommonAppData%\PLUG\Logs|*.*|RECURSE
I had a ton of stuff in there.
Modified entry: [Windows Update *]
Added FileKey9
[Windows Update *]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
FileKey1=%LocalAppData%\Microsoft\Windows\Windows Anytime Upgrade|Upgrade.log
FileKey2=%LocalAppData%\MigWiz|*|REMOVESELF
FileKey3=%LocalAppData%\Packages\MicrosoftWindows.Client*\AC|*|RECURSE
FileKey4=%LocalAppData%\Packages\MicrosoftWindows.Client*\LocalCache|*|RECURSE
FileKey5=%LocalAppData%\Packages\MicrosoftWindows.Client*\LocalState\EBWebview\*|LOG;LOG.old|RECURSE
FileKey6=%LocalAppData%\Packages\MicrosoftWindows.Client*\LocalState\EBWebview\Default\Service Worker\CacheStorage\*|*|RECURSE
FileKey7=%LocalAppData%\Packages\MicrosoftWindows.Client*\Settings|*.log*
FileKey8=%LocalAppData%\Packages\MicrosoftWindows.Client*\TempState|*|RECURSE
FileKey9=%ProgramData%\Plug\Logs|*.*
FileKey10=%ProgramData%\USOShared\Logs|*.etl|RECURSE
FileKey11=%ProgramFiles%\CUAssistant\Logs|*.etl
FileKey12=%ProgramFiles%\Microsoft Update Health Tools\Logs|*
FileKey13=%ProgramFiles%\rempl\Logs|*.etl
FileKey14=%ProgramFiles%\WindowsInstallationAssistant\Logs|*
FileKey15=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\DeliveryOptimization\Cache|*|RECURSE
FileKey16=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\DeliveryOptimization\Logs|*|RECURSE
FileKey17=%WinDir%\SoftwareDistribution\DataStore\Logs|*|RECURSE
FileKey18=%WinDir%\System32\MRT\*|*.log|REMOVESELF
		Revised entry
		Added:
		%WinDir%\Backup|*|RECURSE
		%WinDir%\AppCompat\pca|*.txt
		[Windows Logs *]
Revised entry
I made a mistake in the previous post. This is correct.
Added:
%WinDir%\AppCompat\Backup|*.json
[Windows Logs *]
LangSecRef=3025
Detect=HKLM\Software\Microsoft\Windows
FileKey1=%LocalAppData%\ConnectedDevicesPlatform|*.log
FileKey2=%LocalAppData%\Diagnostics|*|RECURSE
FileKey3=%LocalAppData%\Microsoft\Dialer|*.log.txt
FileKey4=%LocalAppData%\Microsoft\msipc\Logs|*
FileKey5=%LocalAppData%\Microsoft\Portable Devices|wpdlog*.sqm
FileKey6=%LocalAppData%\Microsoft\Windows\Explorer|*.etl
FileKey7=%ProgramData%\Microsoft\Diagnosis\DownloadedSettings|*.json.bk
FileKey8=%ProgramData%\Microsoft\Diagnosis\ETLLogs|*|RECURSE
FileKey9=%ProgramData%\Microsoft\DiagnosticLogCSP|*|RECURSE
FileKey10=%ProgramData%\Microsoft\Network\Downloader|*|RECURSE
FileKey11=%ProgramData%\Microsoft\WDF|*|RECURSE
FileKey12=%ProgramData%\Microsoft\Windows Security Health\Logs|*|RECURSE
FileKey13=%ProgramData%\Microsoft\Windows\wfp|*.etl
FileKey14=%ProgramData%\USOShared\Logs|*|RECURSE
FileKey15=%ProgramFiles%\UNP\*Logs|*
FileKey16=%SystemDrive%|DumpStack.log
FileKey17=%SystemDrive%\PerfLogs\System\Diagnostics|*|RECURSE
FileKey18=%SystemDrive%\PerfLogs\System\Performance|*|RECURSE
FileKey19=%WinDir%|*.log
FileKey20=%WinDir%\AppCompat\Backup|*.json
FileKey21=%WinDir%\AppCompat\pca|*.txt
FileKey22=%WinDir%\AppCompat\Programs|*.txt;*.xml
FileKey23=%WinDir%\AppCompat\Programs\Install|*.txt;*.xml
FileKey24=%WinDir%\debug|*.log|RECURSE
FileKey25=%WinDir%\INF|*.etl;*.log*
FileKey26=%WinDir%\Logs|*.etl;*.log|RECURSE
FileKey27=%WinDir%\Logs\CBS|*.cab
FileKey28=%WinDir%\Panther|cbs.log;DDACLSys.log;miglog.xml;Migrep.html;*GatherPnPList.log;*.tmp
FileKey29=%WinDir%\Panther\FastCleanup|*.log
FileKey30=%WinDir%\Panther\Rollback|*.txt
FileKey31=%WinDir%\Panther\UnattendGC|diag*.xml;setup*.log
FileKey32=%WinDir%\repair|setup.log
FileKey33=%WinDir%\security\logs|*|RECURSE
FileKey34=%WinDir%\ServiceProfiles\NetworkService\debug|*.log
FileKey35=%WinDir%\System32\CatRoot|*.tmp
FileKey36=%WinDir%\System32\CatRoot_bak|*|REMOVESELF
FileKey37=%WinDir%\System32\catroot2|*.chk;*.log;*.jrs;*.txt
FileKey38=%WinDir%\System32\LogFiles|*|RECURSE
FileKey39=%WinDir%\System32\Logs|*.etl
FileKey40=%WinDir%\System32\NDF|*.etl
FileKey41=%WinDir%\System32\SleepStudy|*.etl|RECURSE
FileKey42=%WinDir%\System32\sysprep\Panther\IE|diagerr.xml;diagwrn.xml;*.log
FileKey43=%WinDir%\System32\WDI\*|*.etl*|REMOVESELF
FileKey44=%WinDir%\System32\WDI\LogFiles\StartupInfo|*|RECURSE
FileKey45=%WinDir%\Temp|*.log
RegKey1=HKLM\Software\Microsoft\RADAR\HeapLeakDetection\DiagnosedApplications
RegKey2=HKLM\Software\Microsoft\Tracing
RegKey3=HKLM\Software\Wow6432Node\Microsoft\RADAR\HeapLeakDetection\DiagnosedApplications
RegKey4=HKLM\Software\Wow6432Node\Microsoft\Tracing
Updated.
Added: C:\Windows\%LOCALAPPDATA%\CrashDumps
Added With FileKey4: FileKey4=%WinDir%\*LOCALAPPDATA*\CrashDumps|*dmp*
Notes:
* Has to be written as *LOCALAPPDATA*, since using %LOCALAPPDATA% won't work with there already being a leading path with %WinDir% in it.
* Seems to only store Microsoft Defender Antivirus ("Windows Defender") crash dumps with names like these for example: MsMpEng.exe.4792.dmp, MsMpEng.exe.4804.dmp
[Windows Error Reporting *]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\Windows Error Reporting
FileKey1=%LocalAppData%\CrashDumps|*dmp*
FileKey2=%LocalAppData%\PCHealth\ErrorRep\QSignoff|*
FileKey3=%WinDir%\LiveKernelReports|*.dmp|RECURSE
FileKey5=%WinDir%\pchealth\ERRORREP|*|RECURSE
FileKey6=%WinDir%\pchealth\helpctr\DataColl|*.xml
FileKey7=%WinDir%\pchealth\helpctr\OfflineCache|*|RECURSE
FileKey8=%WinDir%\System32\config\systemprofile\AppData\Local\CrashDumps|*.dmp|RECURSE
FileKey9=%WinDir%\System32\config\systemprofile\AppData\Local\CrashDumps|*dmp*
FileKey10=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\CrashDumps|*.dmp|RECURSE
FileKey11=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\CrashDumps|*.dmp|RECURSE
FileKey12=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\CrashDumps|*.dmp|RECURSE
RegKey1=HKLM\Software\Microsoft\Windows\Windows Error Reporting\FullLiveKernelReports|LastFullLiveReport
RegKey2=HKLM\Software\Microsoft\Windows\Windows Error Reporting\FullLiveKernelReports\win32k.sys
RegKey3=HKLM\Software\Microsoft\Windows\Windows Error Reporting\LiveKernelReports\win32k.sys
RegKey4=HKLM\Software\Microsoft\Windows\Windows Error Reporting\LocalDumps
RegKey5=HKU\.DEFAULT\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation
		Can I consider this project now dormant?
		Twice a year updates are not considered active nor much use, then again this thread is no longer active.
		I used to check this site everyday and still weekly but guess it's time for me to delete a bookmark.
		Merry Christmas and Happy New Year.
You can consider anything you want, you don't need our permission.
