Built in auto update feature for winapp2.ini would be nice, you could put the version+update url in the ini so ccleaner could compare the version of the on disk to the version of the one on the other end of the url
Unfortunately, winapp2.ini is completely unsupported by Piriform, so an update feature that's part of CCleaner is highly unlikely.
For: [MySpaceIM Dump Files*] and [MySpaceIM Images*] change the LangSecref to 3022 since [MySpaceIM] has LangSecRef=3022
Will do!
Windows XP MUI cache is already in winapp2. Are the BagMRUs the same as the 'Window size/location cache' that CCleaner already cleans?
hi
sorry for delay, was pretty busy with life
i can not exactly say what's ccleaner already doing there, because everything is internal. so i can not compare. have to do some regshots first. may take one or two days. bbl
[internet Explorer More*]
LangSecRef=3022
DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe
Default=False
RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache
RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache
RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU
RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup
RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore
RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats
RegKey7=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached
FileKey1=%LocalAppData%\Microsoft\Internet Explorer|brndlog.*
FileKey2=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat
FileKey3=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF
FileKey4=%LocalAppData%\Microsoft\Internet Explorer\Recovery\Last Active|*.*|RECURSE
FileKey5=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.*
FileKey6=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey7=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE
FileKey8=%AppData%\Microsoft\Windows\PrivacIE|*.*|RECURSE
Please remove: FileKey8=%AppData%\Microsoft\Windows\PrivacIE|*.*|RECURSE
Now it is included in CCleaner v3.10
Will do, thanks for pointing that out
How about adding a new entry to wipe Prefetch data in Win Vista and Win 7?
Wiping the prefetch has been show (AFAIK) to have a negative impact on performance.
I guess FileKey paths are not correct.
[Windows System Profile*]
LangSecRef=3025
DetectFile=%WinDir%\system32\config\systemprofile
Default=False
FileKey1=%WinDir%\system32\config\systemprofile\Local Settings\Temp|*.*|RECURSE
FileKey2=%WinDir%\system32\config\systemprofile\Local Settings\Temporary Internet Files|*.*|RECURSE
FileKey3=%WinDir%\system32\config\systemprofile\Cookies|*.*|RECURSE
MODIFIED ENTRIES
[Reg Organizer (Backups)*]
LangSecRef=3024
DetectFile=%ProgramFiles%\Reg Organizer\RegOrganizer.exe
Default=False
FileKey1=%LocalAppData%\ChemTable Software\Reg Organizer\BackupHives|*.*|RECURSE
FileKey2=%LocalAppData%\ChemTable Software\Reg Organizer\backups|*.*|RECURSE
FileKey3=%LocalAppData%\ChemTable Software\Reg Organizer\RegHives|*.*|RECURSE
FileKey4=%Appdata%\ChemTable Software\Reg Organizer|ListsHistory.bin
[Tipard Total Media Converter*]
LangSecRef=3023
Detect=HKCU\Software\Tipard Studio\Tipard Total Media Converter
Default=False
RegKey1=HKCU\Software\Tipard Studio\Tipard Total Media Converter\Edit|LastVideoFilePath
FileKey1=%LocalAppData%\Tipard Studio\Tipard Total Media Converter|*.*
NEW ENTRY
[Glary Utilities (Backups)*]
LangSecRef=3024
DetectFile=%ProgramFiles%\Glary Utilities\Integrator.exe
Default=False
FileKey1=%AppData%\GlarySoft\Glary Utilities\Backups|*.*
FileKey2=%UserProfile%|*.gbck
FileKey3=%LocalAppData%\Microsoft\Windows|*.gbck
FileKey4=%WinDir%\System32\config|*.gbck
That may be true under most circumstances, unless there are items loaded into prefetch that a user deletes (malware, etc?) during a currently logged in session, causing Windows to attempt to load some of those now non-existent entries on re-boot.
Guess it can go both ways.
I personally, would love a prefetch cleaner, as it would be more of a privacy concern to me. I would love to know that were I to choose to do so, I could zap all those entries.
Even more troubling, I have no way of knowing, if Windows tries to create a prefetch entry, how well it does when a program is updated.
Example:
I install Defraggler. Windows creates a prefetch entry for it. Later, I download a newer version that drastically changes the way the program operates, rendering the old pre-fetch entry invalid.
How likely is Windows to update with a "newer" prefetch entry to update to the newer version changes? Not very!
Example:
No, it'll just create a new prefetch file for the new version and delete the old one when its not been used for a set time. No problem caused. And windows won't try to load anything if the related program (or malware) has been removed and its pf file will also be removed after a certain time.
There is NO purpose for cleaning pf data at all, windows does a perfectly adequate job of that itself.
Suggested to add for cleaning XBMC cachefiles (it does it by itself most of the time, not all however)
Also suggested to add cleaning of the packages directory, (storage location for all addons with all updates can get real big)
[XBMC cache*]
LangSecRef=3023
DetectFile=%AppData%\xbmc\cache
FileKey1=%AppData%\Xbmc\cache|*.*|RECURSE
[XBMC packages*]
LangSecRef=3023
Default=False
DetectFile=%AppData%\xbmc\addons\packages
FileKey1=%AppData%\Xbmc\addons\packages|*.*|RECURSE
Hi everyone, I'm pretty new here, but I would like to propose a couple of new entries.
I use SlimDrivers to keep my computer's drivers updated. It doesn't always work, but it does leave behind a fair amount of crap on my C drive.
I propose we split the current SlimDrivers entry into three separate entries as follows:
[slimDrivers Backups*]
LangSecRef=3024
DetectFile=%LocalAppData%\Slimware Utilities Inc\SlimDrivers\
Default=false
FileKey1=%LocalAppData%\SlimWare Utilities Inc\SlimDrivers\Backups|*.*|RECURSE
[slimDrivers Downloads*]
LangSecRef=3024
Default=false
FileKey1=%LocalAppData%\SlimWare Utilities Inc\SlimDrivers\Downloads|*.*|RECURSE
FileKey2=%LocalAppData%\SlimWare Utilities Inc\SlimDrivers\Images|*.*|RECURSE
[slimDrivers Logs*]
LangSecRef=3024
Default=false
FileKey1=%LocalAppData%\SlimWare Utilities Inc\SlimDrivers\Logs|*.*|RECURSE
Also, I use the Vizzed Retro Game Room and its required browser plugin to play video games online.
I propose the following new entry to clean after this plugin:
[Vizzed Retro Game Room*]
LangSecRef=3023
DetectFile=%LocalLowAppData%\VizzedRgr\
Default=False
FileKey1=%LocalLowAppData%\VizzedRgr\Downloads|*.*|RECURSE
FileKey2=%LocalLowAppData%\VizzedRgr\Roms|*.*|RECURSE
I know this is kind of a n00b question, but....
...can anyone tell me what the environment variables are of the browser profiles for the major non-MSIE web browsers (Firefox, Opera, and Chrome/Chromium)?
For the older, but still functional clipboard extension "ClipX" (tested with the 2008 x64 beta version and on Win7x64); it removes temp files which appear over time due to a bug, I guess (e.g. over 1 GB when I deleted the files today):
[ClipX*]
LangSecRef=3024
DetectFile=%LocalAppData%\ClipX\
Default=False
FileKey1=%LocalAppData%\ClipX\Storage|*.*
This update will be a bit late, either tomorrow or wednesday. Still buried under coursework X_x
new update of ccleaner doesn't have the updated entries for AVG2012
so here they are.
[AVG AntiVirus 2012*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\AVG\AVG2012
Default=False
FileKey1=%CommonAppData%\AVG2012\Log|*.log
FileKey2=%CommonAppData%\AVG2012\scanlogs|*.log
FileKey3=%CommonAppData%\AVG2012\Log|*.xml
FileKey4=%CommonAppData%\AVG2012\update\backup|*.*
FileKey5=%CommonAppData%\AVG2012\Emc\Log|*.log
FileKey6=%CommonAppData%\AVG2012\IDS\config|*List.zip.bak
FileKey7=%CommonAppData%\AVG2012\IDS\profile|globalLoadable.bak
FileKey8=%CommonAppData%\AVG2012\Temp|*.tmp
A new entry:
[Freemake Audio Converter (Logs)*] LangSecRef=3023 Detect=HKCU\Software\Freemake\FreemakeAudioConverter Detect2=HKLM\Software\Freemake\FreemakeAudioConverter DetectFile=%ProgramFiles%\Freemake\Freemake Audio Converter\FreemakeAudioConverter.exe Default=False FileKey1=%CommonAppData%\Freemake\FreemakeAudioConverter|*.txt
