SMalik
15 August 2011 17:35
661
Please remove the [setup Logs*] and [Diagnostics Logs*] from Winapp2.ini. I forgot that CCleaner does not remove locked items.
Could you pls rename
to [html Help*]. It looks more professional.
CCleaner entries Paint Shop Pro X3, Paint.NET and Nero Burning ROM 10 are useless. Pls advise them to remove these entries. Also Real Player SP entry name needs to be corrected. It is RealPlayer. I have left messages in CCleaner Suggestions forum in past but, they haven't fixed these yet.
CCleaner cleaned those two entries just fine for me.
SMalik
15 August 2011 17:52
663
You mean [setup Logs*] and [Diagnostics Logs*]?
SMalik
15 August 2011 17:55
664
Please remove [MS Picture Manager*] as CCleaner's [MS Office Picture Manager*] is same.
MODIFIED ENTRY
[MS Clip Organizer*]
LangSecRef=3025
DetectFile=%AppData%\Microsoft\Clip Organizer
Default=False
RegKey1=HKCU\Software\Microsoft\Office\12.0\Clip Organizer\Search\Last Query
RegKey2=HKCU\Software\Microsoft\Office\14.0\Clip Organizer\Search\Last Query
FileKey1=%AppData%\Microsoft\Clip Organizer|mstore12.mgc
FileKey2=%AppData%\Microsoft\Clip Organizer|mstore14.mgc
[MS Robocopy Gui*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Microsoft Robocopy GUI
Default=False
FileKey1=%AppData%\Microsoft Robocopy GUI\Logs|*.*
FileKey2=%ProgramFiles%\Microsoft\Microsoft Robocopy GUI\Logs|*.*
[GameSave Manager 2*]
LangSecRef=3021
DetectFile1=%WinDir%\GameSave Manager_2.0\uninstall.exe
DetectFile2=%AppData%\GameSave Manager 2\
Detect1=HKCR\GSM_gsba
Detect2=HKCR\GSM_gsdu
Detect3=HKCR\GSM_gsms
Default=False
FileKey1=%AppData%\GameSave Manager 2\TaskLogs|*.*
FileKey2=%AppData%\GameSave Manager 2\TaskCache|*.*
FileKey3=%AppData%\GameSave Manager 2\GameCache|*.*
SMalik
16 August 2011 17:56
667
MODIFIED ENTRY
[CrashDumps*]
LangSecRef=3025
DetectFile=%LocalAppData%\CrashDumps
Default=False
FileKey1=%LocalAppData%\CrashDumps|*.dmp
FileKey2=%WinDir%\system32\config\systemprofile\AppData\Local\CrashDumps|*.dmp
Ups I have make some mistakes xD
I have 2
[Teeworlds Demos*]
LangSecRef=3021
DetectFile=%AppData%\Teeworlds
Default=False
FileKey1=%AppData%\Teeworlds\dumps|*.*|REMOVESELF
and
[Teeworlds Demos*]
LangSecRef=3021
Default=False
FileKey1=%AppData%\Teeworlds\demos|*.*|REMOVESELF
please delt both and put this:
[Teeworlds Dumps*]
LangSecRef=3021
Default=False
FileKey1=%AppData%\Teeworlds\dumps|. |REMOVESELF
[Teeworlds Demos*]
LangSecRef=3021
Default=False
FileKey1=%AppData%\Teeworlds\demos|. |REMOVESELF
SMalik
16 August 2011 22:34
669
NEW ENTRY
[Reg Organizer*]
LangSecRef=3024
DetectFile=%ProgramFiles%\Reg Organizer\RegOrganizer.exe
Default=False
FileKey1=%LocalAppData%\ChemTable Software\Reg Organizer\BackupHives|*.*|RECURSE
FileKey2=%LocalAppData%\ChemTable Software\Reg Organizer\backups|*.*|RECURSE
FileKey3=%LocalAppData%\ChemTable Software\Reg Organizer\RegHives|*.*|RECURSE
FileKey4=%Appdata%\ChemTable Software\Reg Organizer|ListsHistory.bin
SMalik
19 August 2011 18:59
670
I guess there was some problem with this forum. I feel some of the posts are gone from here.
It's the whole forum actually, see here:
http://forum.piriform.com/index.php?showtopic=33514
Does 3.09 support regkeys of the form:
[HKEY_CURRENT_USER\Identities\{0A22DB1E-8412-4D38-9011-F2525F13D995}\Software\Microsoft\Outlook Express\5.0\Find History]
where the \{whatever}\ can be anything? similar to the wildcard folder ability in this version?
I do not believe there is wildcard support for the registry.
SMalik
21 August 2011 17:12
674
[Windows CBS Logs*] entry should be removed from Winapp2.ini as it is already included in CCleaner's Windows Log Files.
New entry please
[AM-DeadLink*]
Default=False
Detect=HKCU\Software\aignes\deadlink
LangSecRef=3022
FileKey1=%AppData%\aignes\AM-DeadLink|deadlink.log
I think I have the correct LangSecRef, it checks browser favorites/bookmarks and downloads Fav-Icons, checks duplicates.
A general comment. Since winapp2.ini is getting huge now and many people just use the file and not extracting the entries they need, it would be very beneficial if DETECTFILE entries were replaced with DETECT ones, as reading from the Registry is always quicker than from the hard drive.
SMalik
22 August 2011 01:51
677
MODIFIED ENTRIES
[iTunes Logs*]
LangSecRef=3023
DetectFile=%ProgramFiles%\iTunes\iTunes.exe
Default=False
FileKey1=%AppData%\Apple Computer\Logs|*.log
FileKey2=%WinDir%\system32\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log
[iTunes Temp Files*]
LangSecRef=3023
Default=False
FileKey1=%Music%\iTunes|*.tmp|RECURSE
I have slowly over time switched to Detect= for some entries, but I don't have all of the programs. I will make greater strides towards this soon.
There were ideas floating around for a batch script that would search your drive and place all of the entries that would return true into the file for you, so you'd only have the entries relevant to your drive, but it never happened.
If anyone wants to submit Detect= Paths to replace DetectFiles, I'll gladly replace it.
Can I suggest RegKey6 is removed from:
[*Internet Explorer More]
LangSecRef=3022
DetectFile=%ProgramFiles%\Internet Explorer\iexplore.exe
Default=False
RegKey1=HKCU\Software\Microsoft\Internet Explorer\International|CNum_CpCache
RegKey2=HKCU\Software\Microsoft\Internet Explorer\International|CpCache
RegKey3=HKCU\Software\Microsoft\Internet Explorer\International\CpMRU
RegKey4=HKCU\Software\Microsoft\Internet Explorer\PageSetup
RegKey5=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore
RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats
RegKey7=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached
FileKey1=%LocalLowAppData%\Microsoft\CryptnetUrlCache\Content|*.*
FileKey2=%LocalLowAppData%\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey3=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE
FileKey4=%LocalAppData%\Microsoft\Internet Explorer|brndlog.*
FileKey5=%LocalAppData%\Microsoft\Internet Explorer|*iconcache.dat
FileKey6=%LocalAppData%\Microsoft\Internet Explorer\iconcache|*.*|REMOVESELF
It causes Windows Update site to prompt for permission for its active x every time you run it if this key is cleaned.
Update for Kies
[samsung Kies*]
LangSecRef=3023
Detect=HKCU\Software\Samsung\Kies2.0
Default=False
FileKey1=%AppData%\Samsung\Kies|UpdateLog.txt
FileKey2=%AppData%\Samsung\Kies|UpdateList.txt
FileKey3=%AppData%\Samsung\Kies|.mlca
FileKey4=%AppData%\Samsung\Kies| .mlme
FileKey5=%AppData%\Samsung\Kies|.mlpb
FileKey6=%AppData%\Samsung\Kies| .mlpgb
FileKey7=%AppData%\Samsung\Kies\UpdateTemp|. |RECURSE
FileKey8=%ProgramData%\Samsung\Kies|ConnectionManager.log
