New Temporary folder (Tested on Win2K3 server Std R2 Fr):
%WINDIR%\system32\config\systemprofile\Local Settings\Temp
What else is in Audacity's CFG?
New:
[Windows XP System Profile*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows DetectOS=5.1 Default=False FileKey1=%windir%\system32\config\systemprofile\Cookies|*.*|RECURSE FileKey2=%windir%\system32\config\systemprofile\IETldCache|*.*|RECURSE FileKey3=%windir%\system32\config\systemprofile\Local Settings\History|*.*|RECURSE FileKey4=%windir%\system32\config\systemprofile\Local Settings\Temp|*.*|RECURSE FileKey5=%windir%\system32\config\systemprofile\Local Settings\Temporary Internet Files|*.*|RECURSE
NEW ENTRY
[Audacity*]
LangSecRef=3023
Detect=HKCU\Software\Audacity
Default=False
FileKey1=%AppData%\\Audacity|audacity.cfg
There is an Audacity entry in CCleaner that is listed under 'Internet'. That entry doesn't remove Recent Files from the program. I think that entry should be removed from CCleaner.
Gonna have to vote against that removal because as Winnie Asked:
A whole lot:
NewPrefsInitialized=1 Version=2.0.0 PrefsVersion=1.1.1r1 WantAssociateFiles=0 SnapTo=0 DefaultOpenType=All files LastOpenType= DefaultOpenPath=C:\\Users\\Nergal\\Desktop\\Various Artists_Speech in Delaware_096_data\\e00\\d00 [Directories] TempDir=C:\\Users\\Nergal\\AppData\\Local\\Temp\\AudacityPortableTemp PresetsDir=M:\\AudacityPortable\\App\\Audacity\\Portable Settings\\presets [AudioIO] RecordingDevice=Microphone Array (SigmaTel High Host=MME PlaybackDevice=Speakers / Headphones (SigmaTel RecordingSourceIndex=0 RecordingSource= RecordChannels=2 PlaybackSource= [GUI] ShowSplashScreen=0 [GUI/ToolBars] [GUI/ToolBars/Control] Dock=1 Order=1 Show=1 X=-1 Y=-1 W=327 H=55 [GUI/ToolBars/Tools] Dock=1 Order=2 Show=1 X=-1 Y=-1 W=94 H=55 [GUI/ToolBars/Meter] Dock=1 Order=3 Show=1 X=-1 Y=-1 W=275 H=55 [GUI/ToolBars/Mixer] Dock=1 Order=4 Show=1 X=-1 Y=-1 W=323 H=27 [GUI/ToolBars/Edit] Dock=1 Order=5 Show=1 X=-1 Y=-1 W=377 H=27 [GUI/ToolBars/Transcription] Dock=1 Order=6 Show=1 X=-1 Y=-1 W=140 H=27 [GUI/ToolBars/Selection] Dock=2 Order=1 Show=1 X=-1 Y=-1 W=560 H=55 [GUI/ToolBars/Device] Dock=1 Order=7 Show=1 X=-1 Y=-1 W=520 H=27 [Window] X=0 Y=0 Width=600 Height=440 Maximized=0 Normal_X=0 Normal_Y=0 Normal_Width=600 Normal_Height=440 Iconized=0 [MP3] MP3LibPath=M:\\AudacityPortable\\App\\LAME\\lame_enc.dll [FFmpeg] FFmpegLibPath=M:\\AudacityPortable\\App\\FFMpeg\\avformat-52.dll Enabled=0 [Locale] Language=en [TagsEditor] x=53 y=30 width=494 height=380 [Export] Format=MP3 Path=M:\\AudacityPortable\\App\\Audacity\\Modules [Version] Major=2 Minor=0 Micro=0 [RecentFiles] file01=C:\\Users\\Nergal\\Desktop\\Various Artists_Speech in Delaware_096_data\\e00\\d00\\e00000a8.au
This is a little late, but I just noticed we've reached 100 pages!
Weren't the devs cooking up inline removal for files? Whatever happened to that? They specifically mentioned header removal from INI's at some point, if I recall correctly.
[educated guess with emphasis on guess]I think it never materialized because each ini file is formatted differently[/EDWEOG]
The only thing though is it's audacity.cfg, not audacity.ini. So I don't see how CCleaners inability to allow us to clean ini's would matter much, albeit there isn't much or any difference between the two types of settings files.
Nergal from your post it looks like you're using the portable build. I wonder how different that is compared to a normal installed build. I personally use a much older portable build which doesn't use any .CFG files.
[/EDWEOG]
Hi there Ed Weog!
nope, no difference (AFAIK), cfg file is not part of the Portable experience (portable launcher drops the cfg file in %appdata% and picks it back up when exit
From non-portable version
NewPrefsInitialized=1 Version=2.0.1 PrefsVersion=1.1.1r1 SnapTo=0 DefaultOpenType=All files LastOpenType= DefaultOpenPath=C:\\WINDOWS\\Media SelectionFormat=hh:mm:ss [Version] Major=2 Minor=0 Micro=1 [Directories] TempDir=C:\\DOCUME~1\\ADMINI~1.000\\LOCALS~1\\Temp\\audacity_temp CacheBlockFiles=0 CacheLowMem=16 [AudioIO] RecordingDevice=Microsoft Sound Mapper - Output Host=MME PlaybackDevice=Microsoft RDP Audio Driver EffectsPreviewLen=6 CutPreviewBeforeLen=2 CutPreviewAfterLen=1 SeekShortPeriod=1 SeekLongPeriod=15 Duplex=1 SWPlaythrough=0 LatencyDuration=100 LatencyCorrection=-130 SoundActivatedRecord=1 SilenceLevel=-50 [FFmpeg] Enabled=0 [Warnings] CopyOrEditUncompressedDataFirstAsk=0 FirstProjectSave=1 DiskSpaceWarning=1 MixStereo=1 MixMono=1 CopyOrEditUncompressedDataAsk=1 [samplingRate] DefaultProjectSampleRate=32000 DefaultProjectSampleFormat=262145 [Quality] LibresampleSampleRateConverter=0 DitherAlgorithm=0 LibresampleHQSampleRateConverter=1 HQDitherAlgorithm=3 [GUI] ErgonomicTransportButtons=1 ShowSplashScreen=1 EnvdBRange=60 Help=Local BeepOnCompletion=0 ShowTrackNameInWaveform=0 RetainLabels=0 AutoScroll=1 TracksFitVerticallyZoomed=0 DefaultViewMode=0 SelectAllOnNone=1 EnableCutLines=0 AdjustSelectionEdges=1 CircularTrackNavigation=0 EditClipCanMove=1 Solo=Standard EmptyCanBeDirty=1 [GUI/ToolBars] [GUI/ToolBars/Control] Dock=1 Order=1 Show=1 X=-1 Y=-1 W=327 H=55 [GUI/ToolBars/Tools] Dock=1 Order=2 Show=1 X=-1 Y=-1 W=94 H=55 [GUI/ToolBars/Meter] Dock=1 Order=3 Show=1 X=-1 Y=-1 W=255 H=55 [GUI/ToolBars/Mixer] Dock=1 Order=4 Show=1 X=-1 Y=-1 W=323 H=27 [GUI/ToolBars/Edit] Dock=1 Order=5 Show=1 X=-1 Y=-1 W=377 H=27 [GUI/ToolBars/Transcription] Dock=1 Order=6 Show=1 X=-1 Y=-1 W=140 H=27 [GUI/ToolBars/Selection] Dock=2 Order=1 Show=1 X=-1 Y=-1 W=560 H=55 [GUI/ToolBars/Device] Dock=1 Order=7 Show=1 X=-1 Y=-1 W=520 H=27 [Locale] Language= [FileFormats] CopyOrEditUncompressedData=copy ExportDownMix=1 AllegroStyle=1 SaveProjectWithDependencies=ask [AudioFiles] NormalizeOnLoad=0 ShowId3Dialog=1 [ExtendedImport] OverrideExtendedImportByOpenFileDialogChoice=1 [Library] FFmpegOnDemand=0 [spectrum] FFTSize=256 WindowType=3 MinFreq=0 MaxFreq=8000 Gain=20 Range=80 FrequencyGain=0 Grayscale=0 [Ladspa] Enable=1 [Nyquist] Enable=1 [VAMP] Enable=1 [VST] Enable=1 GUI=1 Rescan=0 [Prefs] PrefsCategory=4 [Window] X=-4 Y=-4 Width=1372 Height=746 Maximized=1 Normal_X=0 Normal_Y=0 Normal_Width=600 Normal_Height=440 Iconized=0 [RecentFiles] file01=C:\\WINDOWS\\Media\\notify.wav
It resets GUI size to its defaults.
that's a gross mischaracterization saad. from the looks of my 2 cfg files above, all/many settings are saved in that file
it sounds like you use only the default settings so aren't seeing the loss of settings deleting this file might cause
default audacity.cfg
Version=2.0.1
SnapTo=0
[Version]
Major=2
Minor=0
Micro=1
[Directories]
TempDir=C:\\Users\\SM~1\\AppData\\Local\\Temp\\audacity_temp
[AudioIO]
RecordingDevice=Digital Audio Interface (WinTV
Host=MME
PlaybackDevice=Speakers (Realtek High Definiti
RecordChannels=2
[FFmpeg]
Enabled=0
[GUI]
ShowSplashScreen=1
[GUI/ToolBars]
Dock=1
Order=1
Show=1
X=-1
Y=-1
W=327
H=55
Dock=1
Order=2
Show=1
X=-1
Y=-1
W=94
H=55
Dock=1
Order=3
Show=1
X=-1
Y=-1
W=255
H=55
Dock=1
Order=4
Show=1
X=-1
Y=-1
W=323
H=27
[GUI/ToolBars/Edit]
Dock=1
Order=5
Show=1
X=-1
Y=-1
W=377
H=27
Dock=1
Order=6
Show=1
X=-1
Y=-1
W=140
H=27
Dock=2
Order=1
Show=1
X=-1
Y=-1
W=560
H=55
Dock=1
Order=7
Show=1
X=-1
Y=-1
W=520
H=27
[Window]
X=0
Y=0
Width=600
Height=440
Maximized=0
Normal_X=0
Normal_Y=0
Normal_Width=600
Normal_Height=440
Iconized=0
audacity.cfg after importing one audio file into Audacity
Version=2.0.1
SnapTo=0
LastOpenType=
NewImportingSession=1
DefaultOpenPath=C:\\Users\\Public\\Music\\Sample Music
[Version]
Major=2
Minor=0
Micro=1
[Directories]
[AudioIO]
Host=MME
RecordChannels=2
[FFmpeg]
Enabled=0
[GUI]
ShowSplashScreen=1
[GUI/ToolBars]
Dock=1
Order=1
Show=1
X=-1
Y=-1
W=327
H=55
Dock=1
Order=2
Show=1
X=-1
Y=-1
W=94
H=55
Dock=1
Order=3
Show=1
X=-1
Y=-1
W=255
H=55
Dock=1
Order=4
Show=1
X=-1
Y=-1
W=323
H=27
[GUI/ToolBars/Edit]
Dock=1
Order=5
Show=1
X=-1
Y=-1
W=377
H=27
Dock=1
Order=6
Show=1
X=-1
Y=-1
W=140
H=27
Dock=2
Order=1
Show=1
X=-1
Y=-1
W=560
H=55
Dock=1
Order=7
Show=1
X=-1
Y=-1
W=520
H=27
[Window]
X=0
Y=0
Width=600
Height=440
Maximized=0
Normal_X=0
Normal_Y=0
Normal_Width=600
Normal_Height=440
Iconized=0
[RecentFiles]
file01=C:\\Users\\Public\\Music\\Sample Music\\Kalimba.mp3
NEW ENTRIES
[MS Office PowerPoint More*]
LangSecRef=3021
Detect1=HKCU\Software\Microsoft\Office\12.0
Detect2=HKCU\Software\Microsoft\Office\14.0
Default=False
RegKey1=HKCU\Software\Microsoft\Office\12.0\Common\Internet|UseRWHlinkNavigation
RegKey2=HKCU\Software\Microsoft\Office\14.0\Common\Internet|UseRWHlinkNavigation
[Roxio Creator 2012 Pro*]
LangSecRef=3021
Detect=HKCU\Software\Roxio
Default=False
RegKey1=HKCU\Software\Roxio\EMC13\VideoUI\RecentFiles\Catalogs
RegKey2=HKLM\Software\Roxio\EMC13\Common SDK\Users
RegKey3=HKLM\Software\Wow6432Node\Roxio\EMC13\Common SDK\Users
MODIFIED ENTRY
Added RegKey2
Please put [snagit 9, 10, 11 More*] entries in sequence
[snagit 11 More*]
LangSecRef=3024
Detect=HKCU\Software\TechSmith\SnagIt\11
Default=False
Warning=This will delete the backups of the captures that you have performed with SnagIt 11.
FileKey1=%LocalAppData%\TechSmith\Snagit|*.bin
FileKey2=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf
FileKey3=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAG
FileKey4=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAGundo
FileKey5=%LocalAppData%\TechSmith\Snagit\DataStore|*.MP4
RegKey1=HKCU\Software\TechSmith\Snagit\11|CaptureCount
RegKey2=HKCU\Software\TechSmith\Snagit\Stamps|StampCustomFolder
saad read my cfg
your entry would make me lose (just picking some here mind you)
SamplingRate] DefaultProjectSampleRate=32000 DefaultProjectSampleFormat=262145 [Quality] LibresampleSampleRateConverter=0 DitherAlgorithm=0 LibresampleHQSampleRateConverter=1 HQDitherAlgorithm=3 [GUI] ErgonomicTransportButtons=1 ShowSplashScreen=1 EnvdBRange=60 Help=Local BeepOnCompletion=0 ShowTrackNameInWaveform=0 RetainLabels=0 AutoScroll=1 TracksFitVerticallyZoomed=0 DefaultViewMode=0 SelectAllOnNone=1 EnableCutLines=0 AdjustSelectionEdges=1 CircularTrackNavigation=0 EditClipCanMove=1 Solo=Standard EmptyCanBeDirty=1
also please put long code or any code in code tags else it overloads the eyes and the thread
I'm thinking it may be best not to muddle with people's settings for Audacity just now. Hopefully the ability to edit in-line on files will be added to CCleaner
you should add an entry for 'Microsoft Mouse and Keyboard Center' which i think replaces IntelliPoint and IntelliType. under these 2 regkeys it creates a subkey for every executable file you run. the only problem with deleting them is if you set any app-specific settings you will also lose those settings. i wasnt sure if these keys also exist for IntelliPoint/IntelliType so i detected it by the install directory instead of the regkeys. thanks and keep up the good work.
[Microsoft Mouse and Keyboard Center*]
LangSecRef=3021
DetectFile=%ProgramFiles%\Microsoft Device Center
Warning=This will also delete any app-specific settings.
Default=False
RegKey1=HKCU\Software\Microsoft\IntelliType Pro\AppSpecific
RegKey2=HKCU\Software\Microsoft\IntelliPoint\AppSpecific
Thanks!
LangSecRef=3021
Default=False
why would one consider app specific settings as junk, they must be manually set so who would want them cleaned every time ccleaner, or any time, ran
Agreed, plus its not saving you any space or cleaning any sensitive MRU entries
BTW you should change to warning to "This will only delete any app-specific settings."
Updated (added RegKey1):
[Paint.NET More*] LangSecRef=3021 Detect=HKCU\Software\Paint.NET Default=False FileKey1=%LocalAppData%\Paint.NET|*.*|RECURSE RegKey1=HKCU\Software\Paint.NET|LastFileDialogDirectory
