WIN98 problem
Tried to install on a WIN98 desktop. Tried several restarts and reinstalls. No error messages - just sits there like a knot on a log. Latest rev d/l'ed today (8/26).
Any help???
You may need the MS Visual Basic 6 SP6 Runtime Files if they're not already installed. Download them, install them, reboot after install.
Did not work. No change. I keep noticing references to "... Runtime Files" (plural). I only got 1 file - vbrun60sp6.exe.
vbrun60sp6.exe installs the needed files (plural) that are required to run not only CCleaner, but a plethora of other programs.
This is what's inside the setup file:
# ?Archive vbrun60sp6.exe - report generated by WinRAR2004-03-10 20:49 ? ? ? ? ?1069 ? ? ? ? ? ? 0 ?vbrun60.inf2002-05-08 06:47 ? ? ? ?147728 ? ? ? ? ? ? 0 ?asycfilt.dll2000-04-12 13:00 ? ? ? ?598288 ? ? ? ? ? ? 0 ?oleaut32.dll2002-05-08 06:47 ? ? ? ?164112 ? ? ? ? ? ? 0 ?olepro32.dll2002-05-08 06:47 ? ? ? ? 17920 ? ? ? ? ? ? 0 ?stdole2.tlb2004-02-23 20:42 ? ? ? 1386496 ? ? ? ? ? ? 0 ?msvbvm60.dll2002-05-08 06:47 ? ? ? ? 22288 ? ? ? ? ? ? 0 ?comcat.dll2002-11-27 13:12 ? ? ? ? 74960 ? ? ? ? ? ? 0 ?ADVPACK.DLL2002-11-27 13:12 ? ? ? ? ?4608 ? ? ? ? ? ? 0 ?W95INF32.DLL2002-11-27 13:12 ? ? ? ? ?2272 ? ? ? ? ? ? 0 ?W95INF16.DLL## Total ? ? ? ? ? ? ? ? ? Size ? ? ? ?Packed ?Files# ? ? ? ? ? ? ? ? ? ? ?2419741 ? ? ? ? ? ? 0 ?10
#  Archive vbrun60sp6.exe - report generated by WinRAR2004-03-10 20:49          1069             0  vbrun60.inf2002-05-08 06:47        147728             0  asycfilt.dll2000-04-12 13:00        598288             0  oleaut32.dll2002-05-08 06:47        164112             0  olepro32.dll2002-05-08 06:47         17920             0  stdole2.tlb2004-02-23 20:42       1386496             0  msvbvm60.dll2002-05-08 06:47         22288             0  comcat.dll2002-11-27 13:12         74960             0  ADVPACK.DLL2002-11-27 13:12          4608             0  W95INF32.DLL2002-11-27 13:12          2272             0  W95INF16.DLL## Total                   Size        Packed  Files#                      2419741             0  10
Those files were installed. Still no luck. :(
Can you boot into Safe Mode?
Will try when I get a chance. PC is not here.
What then?
PC will boot in SAFE MODE. CC works then. Restarted - CC no go.
