Windows 7 32 & 64 Bit can open a directory with more than 3,500 to 5,000 files without locking up.
In XP, if you try to open a folder with 3,500 files, it will slow down a lot. Somewhere between 3,500 & 5,000, XP will lock up & crash no matter how fast your system is or how much RAM. I have one folder with just over 22,000 .EXE files. I also have another folder with over 21,000 high res wallpapers, & another with over 6,000 fonts.
Windows 7 (so far) can open every directory I have without lockup.
* I hated Windows 7 initially because of 2 things:
-> Audio - Creative card had bass & treble controls, so I could take out bass to crank my system while I played drums.
-> Image Viewer -> W7 image viewer is terrible. Try to enlarge pictures, & they get grainy. Try to play animated GIF & it won't. Uses internet browser or media player for that. Not very good when you have GIF files to use, & you like being able to quickly switch to the next or prior like with pictures.
Updated with a creative Audigy card for my 7, then found a way to import XP image viewer into 7. Surprisingly, it DOES smoothly enlarge pictures, & it DOES play animated GIF files.
So, after I spent time to fix a few bugs, I was pretty satisfied overall with my 7.
_____
I don't see 8 being too great from what I have seen, for the following reasons:
-> Interface: Getting to the desktop as a tile is a chore.
-> Doing things take more clicks
-> OS is reduced to choosing basic color for a background for your tiles
-> Start Menu has to be manually added back
-> DVD playback must be manually added back, bought, or 3rd party used.
-> Many people do NOT have (or want) mandatory touch interfaces because their large screen TV/Monitors will be full of fingerprints & smudges
-> New UEFI interface, as opposed to BIOS, may lock out freeware vendors such as Ubuntu/Mint/React OS, etc.
-> According to MS, IE10 may become default, with no option to run FF/Opera/Chrome natively. Will be forced to use a form of IE underneath & just apply their skin. Not sure if this is only for Win8 arm devices, or if they will do this for Windows as well.
The problem with the direction MS is going, is they are breaking all manner of ways that people are used to doing things. They are also (probably) going to break compatibility with all manner of programs that people have used for years. So, Tax/backup/imaging/other softwares will have to be scrapped as they may or may not work any longer with the new UEFI interface & Windows 8.
MS, the way I see it, is on a path to failure with Windows 8. It seems they want to eliminate all competition to Windows, & in addition, make it uglier & harder to use.
This isn't the way to win customers, & if they don't change, I see them failing.
It will definitely be very interesting to see if Windows 8 is the make it or break it for MS, & I definitely will have my eyes open to see what happens!
