I am running WinXP SP2 and my CCleaner version is 1.23.160.
The directory added to the "Custom Folders to Clean" is:
"C:\Documents and Settings\_\Local Settings\Application Data\QuickPar"
I have it set to NOT close upon completion, and it does everything else perfectly.
This is the first issue I've had with this wonderous piece of divine programing.
Please let me know if there's any potential diagnostics you would like to see, or if you believe you may know a solution.
Thanks.
