WiFi Info - False "WiFi not enabled"
Speccy shows the WiFi as "WiFi not enabled"
Speccy: 1.01.132
PC: Dell Latitude D830
CPU: Intel Mobile Core 2 Duo T7100
Network
You are connected to the internet
Connected through Intel® Wireless WiFi Link 4965AGN - Kaspersky Anti-Virus NDIS Miniport
IP Address 192.168.145.26
Adapter Type Ethernet
WinInet Info
LAN Connection
Local system uses a local area network to connect to the Internet
Local system has RAS to connect to the Internet
Wi-Fi Info
Wi-Fi not enabled
WinHTTPInfo
WinHTTPSessionProxyType No proxy
Session Proxy
Session Proxy Bypass
Connect Retries 5
Connect Timeout 60000
HTTP Version HTTP 1.1
Max Connects Per 1.0 Servers INFINITE
Max Connects Per Servers INFINITE
Max HTTP automatic redirects 10
Max HTTP status continue 10
Send Timeout 30000
IEProxy Auto Detect No
IEProxy Auto Config
IEProxy
IEProxy Bypass
Default Proxy Config Access Type No proxy
Default Config Proxy
Default Config Proxy Bypass
Obviously the WiFi IS enabled, since I was able to post this and I do not have a LAN cable plugged in. I ran Speccy on my big desktop last night, which does have WiFi, and it showed this status:
Network
Connected through NETGEAR WN311T Wireless PCI Adapter - Kaspersky Anti-Virus NDIS Miniport
IP Address 192.168.xxx.2
WinInet Info
LAN Connection
Local system has a valid connection to the Internet, but it might or might not be currently connected
Wi-Fi Info
Using native Wi-Fi API version 1
Available access points count 1
Wi-Fi ()
SSID
Name
Signal Strength/Quality 78
Security Enabled
State The interface is connected to a network
Dot11 Type Infrastructure BSS network
Network Connectible
Network Flags There is a profile for this network
Cipher Algorithm to be used when joining this network AES-CCMP algorithm
Default Auth used to join this network for the first time 802.11i RSNA algorithm that uses PSK
