Where are the Defraggler logs stored by default? I love this program, other than the logs it generates...takes up huge space on my hard drive, and I want to find these logs so I can delete them.
Thanks in advance.
Thanks in advance.
Thanks in advance.
...I don't believe that Defraggler does produce a log...unless you explicitly
invoke in debug mode, whereupon it will produce a log in the same folder
as the executable. See the following topic...
http://forum.piriform.com/index.php?showtopic=12840
If you don't kow where the logs are, why do you think Defraggler is
producing them ?
Just to check, I've run Defraggler and then reindexed all my disks
and sorted a listing by date: I could find no trace of a log file or text
file pertaining to Defraggler [loads of Widows logs etc, though !].
-thm
