What's going on?
I have an Acer machine which has 2 partitions on it (C and D) and another hard drive as slave.
When I defrag the C it now shows about 1.4 lines of mostly blue but some red then 3.6 lines of white followed by 2 lines of mostly red.
I have ran the defrag several times and it does not improve.
When I defrag E it shows about 1.1 lines of all blue with only two reds but several blues scattered throughout the rest of the white and a few reds as well. At the bottom row right are 4 reads and several golds.
Every time I click on defrag it starts and runs for about 15 mins moving stuff around but when finished not much seems to have changed.
What is going on and what is the solution? (I did an update before I started.) - jb
Maybe someone here at the forum can help you if you can give the files that are not being defragged.
Can you run the defrag in debug mode and then PM with details of the log and I will look into this.
MrRon
MrRon
Ron, how do I do this? I just went back to the program and don't find a way - and nothing in "help" either.
And, Don, over half the drive is showing red - it is not just a couple of files.
This might help: Running Defraggler in Debug mode
Keith
Keith
Tks, Keith - will do so right now. - jb
Ran in Debug and have about the same results - as it has done in the past, every time I run defrag it comes up with a different number of files that need to be defraged - maybe 56 then 138 then 44, etc.
Ron wanted me to send him a file - how do I find the file?
tks - jb
If you installed Defraggler to
C:\Program Files\Defraggler\Defraggler.exe
look inside it and there should be
Defraggler_log[date].txt.
