on the cleaner.....windows and applications.....what should be checked or not.....have used ccleaner since almost from the beginning and no harm to my system EVER....best cleaner on the net'.......have left it alone and never unchecked anything and on the issues,any issues are found are deleted or fixed.....is this ok or what should be unchecked..
For example on applications....when it is cleaning regedit or spy sweeper....what is it cleaning?
any help would be appreciated..............
