What Locations Are Cleaned with /AUTO?
I see several threads about the /AUTO command-line parameter for CCleaner, but I didn't find anything that explains which locations are cleaned with /AUTO. Does it clean all locations? Or does it use the locations that were chosen on the latest previous manual CCleaner run? Or some other group of locations? Is there a way for me to specify which locations are cleaned with /AUTO?
TIA,
Phil
Hi Phil,
There's no difference between "/Auto" and manually pressing "Run Cleaner" in CCleaner, at least in that respect.
Both will clean those locations you've set previously.
