what does the "System Restore" button do?
I have SR disabled and don't want it enabled since I have a better alternative, so I don't want to even test the button. Thank You!
Hi slowday.
The button is simply used to delete restore points, although the last restore point can't be deleted as a safety measure.
You can quite happily press it, and in your case the graphic will spin momentarily and then stop as you have nothing to list.
Hi slowday.
I did suspect that is what it did! Thanks again!
