What does it mean if console is set to active under Remote Desktop?
http://imgur.com/t1GtCFt
I'm sure it's nothing, but I'm a little paranoid, so I thought I'd ask. It says that remote desktop is disabled, but why is console active?
console is always active, it is the currently logged on session that will be remotely controlled if Remote Desktop is Enabled in Control Panel, System, Advanced system settings, Remote tab.
