I have a pretty bad virus on my computer, and I think the best option right now is to clear off my C drive and start over. However, I don't have my reinstall disks or anything to reinstall Windows (XP). Can the "Full Wipe" feature in CCleaner clean off my drive without reinstalling Windows? I'm pretty sure that's what it does, I just can't seem to find anything out there that says exactly what it does. Thanks in advance.
Follow any steps here that you are able to do (and that the virus allows you to do)
http://forum.piriform.com/index.php?showtopic=20120
and then post any logs that you have managed to do in the Spyware Hell part of this forum in a new topic
http://forum.piriform.com/index.php?showforum=12
edited to show correct link
That thread doesn't have any steps or anything in it...??
