Web Browsers.
I use Internet Explorer, as my web browser, and was planning to download another (probably Mozilla Firefox or Google Chrome) browser.
Would using different browsers at different times, to access the net, cause any problem or conflict on my PC?
No.
You can even have multiple different browsers open at the same time surfing the web, doesn't hurt anything either other than system resources being higher to run both simultaneously.
Thanks for the replies/information.
Only conflict would be over which opens HTML and such as the default browser.
Get FF and use the IE add-on when needed. Best of both worlds.
use the SRWare Iron browser. it's just like chrome but with many security and privacy features built in. i use FF and Iron and love them both. never any problems.
http://www.srware.net/en/software_srware_iron.php
http://download.cnet.com/SRWare-Iron/3000-...4-10889248.html
Welcome to the forums PuertoUSA. :) We know of SRWare Iron as it's been one of the most highly requested for CCleaner to clean. If you want a currently unofficial but tested CCleaner support for SRWare Iron check out this post.
I have downloaded Mozilla Firefox, but want to keep Internet Explorer as my default browser.
I went into You Tube, using Mozilla Firefox, tried to play a video, and was told I had to download the Adobe Flash Player plug-in.
When I look at "Add/Remove Programmes" it states I have Adobe Flash Player 10 ActiveX. I can access You Tube videos with Internet Explorer, but would like to be able to use Mozilla Firefox as well.
Can I simply download the Adobe Flash player plug-in again, to achieve this, even though I already appear to have it?
I assume the Flash player plug-in is the same thing as Flash Player 10 ActiveX.
yes download it again, this time it will be a Firefox plug-in,
If you go to the Adobe download site with Firefox, it will install the right version. The same goes with other browsers, whichever one you access the download page with, it installs that version.
http://www.adobe.com/shockwave/download/do...rowser=Netscape
has anybody used this chrome plus?....http://www.chromeplus.org/default.html
btw espect later firefox 3.5.5 and new opera dev.
The best browser to use if your unsure of which one to use is Firefox, but you might find Opera a little bit faster.
