Warning! With EasyCleaner
There is an issue with the EasyCleaner Registry Scan. When you delete the registry issues, you will then delete your custom folders along with it. So watch out for this and hope this helps you people who have EasyCleaner.
Jobartley515
That was the reason my custom folders disappeared! I use both CCleaner and EasyCleaner, so it often happens that to me! Thanks for the info, jobartley515!
In EasyCleaner's registry cleaner input to skip: CCleaner
This will stop it from messing with CCleaner.
Note: EasyCleaner isn't the only program that will mess with CCleaners settings in the registry.
Thanks for the Information Andavari! :D
Jobartley515 B)
Note that EasyCleaner doesn't remove anything from the registry automatically, it shows you what it's found, you can highlight and delete one at a time or "Delete All".
I suggest you look at that list carefully before you click "Delete All">
