w2k, CCleaner 1.41.544 -> Explorer Problem
so, for the moment i will make the last try with the windows repair- if this can?t fix the problem, than it would be better to reinstall (new) the w2k-again (inkl. the progs) - also a reason not to install old programms, or with other words, to have a clean system ;)
I was talking with a collaeuge, witch is useing also CCleaner, also with w2k.. and he have no problems...
So maybe, it could be, that after2 or 3 years of fine working, it is realy on time, to reinstall everything -you know, a microsoft problem ;)
It could be, that a other programm will disdurb, i duno
Maybe, it was a mistake also done by me (I was just useing the normal settings), and something important was deletet too... i duno
However, thx for your passion, also step-by-step explaining (a lot of moderators of opther forum could learn a lot from you/your behaviouse), even cause it?s a free-programm :D:
Thx. and i will let u know, what camed out.
Edit:
So, i tryed with the self-repair; but the result was the same as before; so i gave up and reinstalled w2k (btw. i also rechanged the HD and modify some things, so at least, it was also good foor a Hardcleaning inside and so on).
Thx. again fur your passion.
I also delete some of the results for securty reason; so if this thread is not longer needed u can close or delet it.
thx
peewee
