Here is a new visual Style I have been using this past month. It's a self installing file to the resource folder I had no problems with the install or any adverse affects, everything works fine. Theme includes Wallpaper,Vista sounds,cursors and Icons.
Do you have a link for the theme res45?
Dud!! Can't believe I left that off.
Hi res45,
I saw something like this on a video downloaded with my Metacafe software. I thought it looked brilliant, but didn`t have the bottle to try it.
Can you revert OK if you feel the need ?
Regards
Edit: Just looking along your taskbar in the pic. Is that Media Player 11 I can see? If it is, how have you found it ?
Hi res45,
Regards
The Royal Remix has it's own uninstaller and it works fine I'm using it on 2 of my computers with no problems at all as far a MP 11 goes its a nice change had no problems with any of the functions I like the library interface allot better.
thank you, its a good balance, I've gotten bored of the overload from Windowblinds and w/e else i had.
awesome, i too was using windows blind.
it was way too bloated.
i think ill be using this for a while now if it works.
