Visual Basic 6 Runtimes errors
Hi,
When starting up CCleaner with the "MSVBVM60.DLL or other Visual Basic related error message" you are are presented with the option to download the Visual Basic 6 Runtimes from Microsoft
Take Care:
these runtime libraries are the Service Pack 5 libraries of Visual Basic and they are NOT for WinXP SP2.
If you are running WinXP you need the Service Pack 6 version of Visual Basic:
Visual Basic 6 service pack 6
"I Edited out the statement that this will corrupt your WinXp because that is not true"
Solution: Fix CCleaner MSVBVM60.DLL crash errors - Also fixes other VB related errors.
Solution: fix the link presented by crapcleaner
Windows XP doesn't use Visual Basic run-times. Visual Basic programs do.
the link should be fixed though
i was only trying to help improve a highly appreciated piece of freeware
sorry if i went about it the wrong way
same here; I abused you in the other thread, my apologies.
N.P. :D
my apologies for adding some unintended confusion to the "regisrty messed up" thread
(just delete my postings in that thread if you like)
