Viewing in Registry not resetting
After I scan for issues in the Registry, I click on a few of the entries to see where it is in the Registry itself. Regedit open and navigates to the correct place. But if I leave Regedit open and I click on another CCleaner scan issue and go to see where it is in the Registry again, it no longer navigates to the new location in Regedit. It stays put from the first lookup entry. Only if I close Regedit between each CCleaner Registy lookup does it work.
I would like it to move for each lookup while the Regedit application is already open. Worse case is to have CClearner close and reopen Regedit by itself.
-Dave
