Hello- used CCcleaner for years. Tried it recently on a new cpu after downloading directly from Piriform. However, after every scan chrome automatically gets changed to use the V9 search engine as a a default and v9 as a home page. Ive removed and changed v9 manually so this only happens after a cccleaner run.
Is this malware, is there anyway to get rid of this. It ruins an otherwise great product....thanks
If you suspect malware on your computer see item #10 in the forum rules which lists malware removal forums/sites that will help you remove the malware for free.
