Windows 10 Pro 64 bit v. 1803 including all current updates
Windows Home 64 bit 1803 including all current updates
CCleaner v5.44.6575 64 bit free version
Since upgrading to v.44.6575 CCleaner does not clean on startup, even though that option is selected in Options/Settings. The CCleaner icon in the taskbar says "CCleaner (Cleaning...)" but does not show a percentage like previous versions. When opened CCleaner is not cleaning, so the taskbar icon never reverts to "CCleaner monitoring is active" after cleaning.
When reverting to v.5.43.6522 it behaves as it should - cleaning on startup, correct taskbar icon messages.
<a contenteditable="false" data-ipshover="" data-ipshover-target="<___base_url___>/profile/39092-pierres/?do=hovercard" data-mentionid="39092" href="<___base_url___>/profile/39092-pierres/" rel="">@PierreS</a> <a contenteditable="false" data-ipshover="" data-ipshover-target="<___base_url___>/profile/82767-pvasileff/?do=hovercard" data-mentionid="82767" href="<___base_url___>/profile/82767-pvasileff/" rel="">@PVasileff</a> <a contenteditable="false" data-ipshover="" data-ipshover-target="<___base_url___>/profile/4343-alanbo/?do=hovercard" data-mentionid="4343" href="<___base_url___>/profile/4343-alanbo/" rel="">@alanbo</a>
Are you able to provide some further information to help with our investigation. For example what anti virus solution are you using?
I'm using Windows Defender, the built-in anti-malware protection. No other resident protection. If you need more specific info, don't hesitate to ask.
<span style="float:none;background-color:rgb(255,255,255);color:rgb(53,60,65);font-family:Roboto, 'Helvetica Neue', Helvetica, Arial, sans-serif;font-size:14px;font-style:normal;font-variant:normal;font-weight:400;letter-spacing:normal;text-align:left;text-decoration:none;text-indent:0px;text-transform:none;white-space:normal;word-spacing:0px;">I'm using Windows Defender, the built-in anti-malware protection. No other resident protection. If you need more specific info, don't hesitate to ask.</span>
@Ben Piriform I just sent a crash report. I used the same email address as here so you can identify me.
<a contenteditable="false" data-ipshover="" data-ipshover-target="<___base_url___>/profile/39092-pierres/?do=hovercard" data-mentionid="39092" href="<___base_url___>/profile/39092-pierres/" rel="">@PierreS</a> was the crash in relation to this startup issue?
I assume so, it occurred just as I was logging on to my computer, and CCleaner is set to clean at startup…
