v5.09.5343 still skipping files with Edge. New problem as well.
The problem has not improved at all from the last version of CCleaner. It still randomly skips some, or completely skips all Edge files. I've tried turning Edge on and off in the background, and restarting to make sure it's set that way as well, but it makes no difference afterwards using CCleaner, it sometimes works upon a restart.
I also ran into a new issue, after using CCleaner a few times and testing to see if anything actually worked, and not just temporarily. I noticed upon opening Edge again, it would not display its normal page with news and such, nor would it display frequented sites like it normally does. I then tried clearing the history in Edge and it gave me the message "some data could not be deleted." Restarting my computer fixed the problem, but it only occurred after using this latest version of CCleaner. This hasn't happened to Edge before when using the previous version of CCleaner.
