After update to v2.00.500 execution results in "The procedure entry point Process32First could not be located in the dynamic link library KERNEL32.dll." Only option is to press okay to terminated the error notification window; CCleaner does not open.
Could you please tell me if it worked with an older version of CCleaner?
I am having the same problem but have never used CCleaner before so I would like to know if the solution could be to use a previous version.
I'm having the same problem with the new version of CCleaner under NT4 Server. (It worked fine for me under XP.) I tried an older version (v1.xx) on my NT4 Server, it worked fine.
