v2.0 Interface Bugs
1.)When making inclusions and you are adding folders with long path names, the end gets cut off. Not sure if this is sure for Exclusions.
2.)In the program uninstaller part, when attempting to delete an entry of a program that has been installed by windows installer, a popup with no words pops up. Before it said that MSI files can't be deleted or something like that.
Not sure about the first issue but the second, yes I get that as well.
It is definitely a bug.
Thanks I'll get this fixed.
